Where in havasu can I find a sbc marine starter?
ka0tyk
Mine makes a terrible grinding sound and smells. Need a new one to finish our holiday weekend. Is there any shops or anyone have one lying around. Super appreciate any help. Thanks!
Mototrig
Sorry I don't know of one for sale.
But if you're in SoCal and you end up needing to rebuild yours after this weekend I know of a shop in Garden Grove that rebuilt my SBC marine starter. They also rebuilt the original window motor in my Chevelle. Good luck.
DC Automotive Electric
10505 Stanford Ave
Garden Grove, CA 92840
714-828-7681
FreeBird236
Alternator Specialties @ 1944 Acoma is the guy for rebuilding or exchanging starters, but won't be open till Monday. I'm thinking your only possible choice is the usual Auto Zone, O Reilly's.
Bobby V
Havasu1986
They’re open on Monday. Labor Day?
DarkHorseRacing
Tomorrow is Sunday and most auto parts places are usually open sundays. Labor Day might be limited hours or closed, but cars always need parts so it would be odd to be totally closed.
coolchange
Lower level functionary
There is an auto parts in Parker just below the main intersection next to bad attitude. I’ve gotten odd parts there like NGK 2 stroke plugs etc.
Napa on Arizona just below 95
D19
I have one you can have if you want to drive up to Fort Mohave. It came off a 509 I had. Stock starter. I can’t gaurentee it will last you forever but should get you through the weekend if that’s all you need.
ka0tyk
Ended up just grabbing an autozone git r done marine special and I have a sierra replacement from amazon on the way long term. West marine wanted a crazy amount.
Welp tried to put it in but diameter was incorrect so wouldn’t go in the hole. Back to square one.
Bobby V
Havasu1986
I was referring to the post about Alternator Specialties. Not the auto parts stores. 😉
sintax
I’m heading out early-ish tomorrow. Prob 8
If someone in the IE (Corona / riverside) has one I can bring it out. I’ll be up for a couple of hrs.
JFMFG
auto zone
wzuber
See if you can get a # to connelly marine. I'll bet he has either style you might need..you'll need a hook up # tho for tomorrow most likely.
Maybe Barry @obnoxious001 has one you can use or knows where to get 1.
wzuber
Pretty sure BBC & SBC are interchangeable but there are diff bolt patterns and styles. The large diameter with the bendix support cone and the smaller style with just an exposed bendix..
sintax
I think they’re typically closed on Sundays
sintax
Correct, hence the " hookup" # reference.
Ah I got ya.
If you end up going this route grab a 1” magnaflow impeller for me plz! Hahaha
I can’t remember if I have one on the shelf or not.
Icky
You can try calling parker auto in the morning
Fun Times
Moderated
Assuming you have a Mercruiser small block (though I’m not sure of your engine year, serial number and OEM starter part number, etc., for definite) but thinking you may have Merc part number 50-863007A1 in which would be 18-5913-1 in the Sierra Marine aftermarket, if so then NAPA auto in Lake Havasu online suggests calling them for certain availability on some and pick up tomorrow on other starter types.
If you know your OEM part number, run it in both Marine Engine.com linked below to look for the Sierra aftermarket part number in which would be marine compliant for safety vs an auto starter ‘then run either the OEM number or Sierra number in the search bar at NAPA to see if they have a better match up.
Find your engine manufacturer, year, starter part number to see the list of options then check NAPA.
Jonas Grumby
The Skipper
Connelly, down the street on the right from sun county marine.
obnoxious001
Engine building character
I sort of doubt Parker Auto Parts is open today, but pretty good chance they have a Sierra. I may be able to text one of the employees and pull a favor.
Spanky's should be open, and may have one, but it will cost more.
ka0tyk
open and had 3 sierras. Thank you!
ka0tyk
Apparently the owner figured there was money to be made on Labor Day weekend since people will still want to run their boats tomorrow. Nice that you were able to catch them.
Yup that’s us. The starter bendix I think stuck and it revved to the moon once the motor started. Smelled something funny and the next crank was barely able to start. Labor Day saved.
Also I used our dinghy to tow this boat to the springs that broke. Halfway there I heard the radio booming and the girls were twerking on the rear hatch the whole way there. Was a great time. Lol.
