Vintage aluminum rim repair
Toolman
One of my customers hits all the Junkyard‘s on a daily basis hunting for vintage aluminum rims. When he finds them, usually the guys at the junkyard take a sawzall and cuts the tire off and damages the rim in the process. Somebody had already welded up this rim and did a shit job and when they ground off the weld the slot from the Sawzall showed up again. So the proper way to do it is to V groove out the slot so you can get plenty of weld rod into the valley. My customer has a guy that can grind this rim down and make it look like new.
ltbaney1
repair looks good. im suprised the yard does that to the wheel. i would think they wouldnt want to damage it to be able to get top dollar for it.
Toolman
The yard just wants the rim for aluminum recycling. My friend hits all the Junkyards and says you wouldn’t believe how many bitchin rims and classic cars that have gone to recycling and/or the crusher. He gives them a finders fee if he gets a phone call that a 65 impala, for example, is heading for the crusher.
mattyc
One of my customers hits all the Junkyard‘s on a daily basis hunting for vintage aluminum rims. When he finds them, usually the guys at the junkyard take a sawzall and cuts the tire off and damages the rim in the process. Somebody had already welded up this rim and did a shit job and when they ground off the weld the slot from the Sawzall showed up again. So the proper way to do it is to V groove out the slot so you can get plenty of weld rod into the valley. My customer has a guy that can grind this rim down and make it look like new. View attachment 1487944 View attachment 1487945 View attachment 1487946 View attachment 1487947 View attachment 1487948 View attachment 1487950 View attachment 1487951 View attachment 1487955 View attachment 1487956 View attachment 1487957
Nice! What fill rod did you use for that? And why?
Toolman
Alloy 5356. It is the general purpose alum rod. Used 10 cfm’s of argon and 5 cfm’s of helium to get good melt. The rim acts like a big heat sink. The heat is traveling away from the area very fast.
HNL2LHC
I have welded very little aluminum over my years but it is crazy how fast it seams to dissipate the heat. Unlike steel welding where the puddle seams to last so much longer in the welding process.
