bagged97taco
- Jun 20, 2011
- 1,859
- 3,053
no Bergeron, casale, lenco , pretty much called everyone I can think of for Vdrive’s. It’s an older style flange so gonna be hard to find. But I need one asapBergeron Engineering??
Yep no luck at Connelly.Connelly Marine?
That’s the issue. We have 2 races left with this setup then going to a bigger power plant and a clutch in the boat. So this new shaft is for 2 races only.If you absolutely can’t find one it isn’t impossible to make. I’d have to price out that broach though
X2 Glenwood MarineGlenwood?
Good luck with glenwood , they never answer the phone and they are almost closed doors . It’s only the woman that works there now .X2 Glenwood Marine
Good luckIll try menkins today. Thanks guys
When I stop by Glenwood I always go in though the backGood luck with glenwood , they never answer the phone and they are almost closed doors . It’s only the woman that works there now .
Thats the only way to get in and they're always there.When I stop by Glenwood I always go in though the back
Thanks for checking. Kinda at a loss with this. May have to switch up our whole program.Sorry I don’t have anything. Just the standard and a 21 tooth.
Yea tried jj. I think we have it figured out. Between my lake flat and the race flat we can make it work with what we have. We will see soonthat sucks I run whats in your 1st post 10 spline, did you try JJ beaver fab? worth a shot
No. We ended up ordering a new solid driveline from mark Williams. He makes 16 splines. But they aren’t the same 16 splines as casale. So we put it all back together the way it was and didn’t have any issues making 14 passes down the track spinning 8k rpms.Bringing this back up because I went out and checked my "new" solid driveline setup and I'm missing the flywheel end coupler. The shaft is 16 spline as well, wondering if you ever found anything?
Do you need the crank button for a 16 spline. Mounts to flywheel pto? I have one on my canyon. But I think I found one for sale somewhere. I’ll try to think where and let you know.
I’ll look for where I saw it. And let you know.Yes! That is what I will need. Glad I reread this thread cause I missed this post the first time through. Thankfully the v-drive side is sorted out.
Did anyone ever find one? Nobody has any 16 spline Casale stuff….I know this post is way old I’m getting desperate…Do you need the crank button for a 16 spline. Mounts to flywheel pto? I have one on my canyon. But I think I found one for sale somewhere. I’ll try to think where and let you know.
