Truck battery/charging system question
bobbytheboozer
resident boozer
2006 chevy 2500hd gas, single battery set up.
The truck would usually run anywhere from 13.6v to 14.2v. Yesterday morning I had to jump it to get it started. Omw to work yesterday I noticed on my tuner screen (Edge cts2 evolution tuner) the truck was running at high 11v to 12.4v. I unplugged the tuner and didn't have issues yesterday.
This morning, it fired right up (tuner still unplugged) I got to work and parked. With the truck running at idle, the truck gage is showing a little over 10v. I just took it around the block and the voltage goes up on the truck gage to 14v.
I figure the battery is taking a shit because of all the recent heat. What does everyone think?
It's a crap triple A battery that I got in a pinch 2 years ago.
Jefftowz
Formerly Old School Ultra
Don't trust the factory gauge, also call AAA and have them replace the battery to be safe. They will check the alternator output also.
bobbytheboozer
resident boozer
Check your alternator voltage regulator.
have batt and charging system checked
Yea I am going to have to do all of this. After I shut my truck off to go into work, I waited 30 seconds and turned it over again. Slow chugging for a second then it fired up.
bobbytheboozer
resident boozer
I have a few more questions. What are the amps on a stock 6.0 gas chevy alternator? If I run a high amp alternator, do I have to run a special battery like an optima?
jones performance
check your cables both pos and neg for any corrosion at both ends and make sure they are tight.
stock alt are either 105amps and 145amp if i recall correctly.
bobbytheboozer
resident boozer
They both looked good yesterday morning when I jumped it. I never jump off the battery though.
I'll double check it when I get a chance today. Thanks for the reminder! [emoji106]
Justfishing
A bad battery can make an alternator go bad. Also a bad alternator can make a battery go bad.
Inspect all cables. Also check over any grounding straps which are frequently over looked as they are not in the open. Adding extra grounding straps is a good insurance policy with all the electronics in cars.
bobbytheboozer
resident boozer
Right on. I do have quite a bit of electronics in my truck. Light bar, good sized stereo, tuner ect.
nowski
We just got the AAA runaround early last week on my daughters vehicle. It took 3 days and a dozen calls before we finally got a battery, luckily for us she hasn't started school yet. They said they were out of stock that is until my wife finally got on the phone and went up the corporate ladder. Like I said we got the runaround (with not a single battery in So. Cal) and when we finally did get a battery the date code was 3/17. What that means to me is they confirmed their story was nothing but a bunch of BS.
My advise to you is to make sure that battery is dead and gone before you make that call to AAA. When on the phone with AAA let them know exactly what battery you need so when they do arrive they won't come empty handed. When they do finally put that battery on their scanner have the technician not only show you the results but have him give you a printed copy. Your going to need to put up a fight to get a new battery the question is, is it going to happen in the first round or the twelfth round???
When you get a moment check out some of these complaints, after our ordeal it not only became a reality but an eye opening experience...
http://mythreecents.com/reviews/aaa-battery
bobbytheboozer
resident boozer
I'll have to look at that link later. I hope it's not that much of a pain to get a battery. I'll flip on them.
It was nice meeting you last weekend at eliminator!
nowski
why the hell would you buy a battery from AAA?
It's all about safety and convenience that's how we ended up with ours. My wife's battery died late one night and called out to AAA for Help. The original battery in her vehicle was 6 years old so it was time for a replacement, it just decided to die at a bad time. She got home safely that night and that was my number one concern. I try to buy nothing but Bosch Batteries but in this instance it slipped through the cracks...
SBMech
Fixes Broken Stuff
Either something is not turning off, or you have a bad plate/cell.
Occasionally I see these delco alternators not want to charge till they are running at 2k+ RPM, a failing alternator.
At idle it should be putting out 13.2 volts minimum, 14.8v max with the lights/AC/stereo on. Less than that you have a charging system problem.
I have seen batteries cause charging system problems and alternators kill batteries. Get a volt meter on it so you can stop guessing. :D
The right way is to check the amperage output, but a simple voltage test will usually suffice in a situation like this.
BTW I LOVE AAA batteries...they make me so much money when I replace them :skull
bobbytheboozer
resident boozer
I was going to get home and work on it today, but this weather is something else. It's pouring and lightning just structure a few blocks away.
Kailuaboy89
Aloha Airliner
Battery sounds like it has a bad cell, or more going south on you, and the alternator is struggling to keep up, on maintenance free batteries the cells sometimes just take a shit, and then you will not have full voltage or cranking amperage for proper starting, and also being able to properly run accessories on the vehicle.
SPL2K
You need to check the voltage at the battery with a hand held digital multimeter (Fluke) while its running and then again after its been off for awhile. Doors closed, all lights, etc off.
bobbytheboozer
resident boozer
I am going to swing by autozone after I get out of work and have them run a charging system/battery check.
I just got to work, shut off the truck for a few minutes and then fired it back up. The subwoofers were making a muffled sound and made a deep pop sound when it fired up. [emoji20] It wouldn't surprise me that the problem is the stereo. The guy that installed it, supposedly was a good stereo guy. I beg to differ. I always get a funky distortion sound. Tony (DT1000) told me a while ago to go to al and ed's to get it checked out. I'm gonna have to do that this weekend.
jones performance
it amazes me how many hacks there are installing car audio.
bobbytheboozer
resident boozer
You can also add boat audio to that list...
Oh yea. It amazes me what install guys will pass off as "professional installation". The mounting bracket for my head unit is broken, the truck has a bose sound system which sounds great but with an aftermarket head unit needs a decoder that was probably installed wrong since I've always had this annoying distortion problem. It'll work well and sound good for 1 or 2 days up to a few weeks, then go back to shit.
bobbytheboozer
resident boozer
Went to autozone and had them test everything.
Battery: good
Starter: good
Alternator: bad. Not charging the battery at idle. So it's just eating up the battery.
So I know what I'm doing this weekend. Lol.
fishing fool
Battery: good
Starter: good
Why wait until the weekend? It's only a hour job at most
bobbytheboozer
resident boozer
So before getting ready for bed, I decided to go poke around the truck and check everything out. I went through all the bolts that go from the battery to the alternator. The yellow arrow pointing to the main bolt in that Positive block next to the alternator was very very loose. Another 2 or 3 turns and it would have fallen off. I tightened it up and it seemed like the lights were brighter, drop down side steps moved faster.
I fired up the truck, grabbed my multi meter, put it on 20v. It was showing 14.25v. When I stopped by autozone, when they tested it, it was showing 12.2-12.3v.
Could that loose bolt be the reason for my electrical demon headache? It seems too easy for my luck.
Jefftowz
Yes, that could of been the issue.
bobbytheboozer
resident boozer
I think that loose bolt was the problem. Smh. I'm amazed because, with my luck, whatever the fix usually is, it's the most expensive one.
I brought my multi meter with me this morning. After I get out of work later today, I'm going to test everything again. Battery voltage, voltage drop ect.
mjc
Retired Neighbor
Who installed the wire on that stud? They never tighten in down afterward.
bobbytheboozer
resident boozer
It could be the shop that added a bunch of accessories to my truck about a year ago. I'm thinking that it over time it backed itself out. I'm gonna have to keep my eyes on it.
fishing fool
Question???? It's bugging me that auto zone tested and said "bad alternator"
Where did they test it at? If they tested it right from the alt then the loose nut it not the problem.
Yes the loose nut is a issue and can cause a bad connection making it not to charge the system.
nowski
Sometimes in Life, the best fixes are the cheapest if you investigate the problems yourself. Just imagine what it would have costed you if you took it to a dealer? An arm and a leg would be my guess...
About 7 years ago we found ourselves stranded on the beach at Avi, boat wouldn't even turn over. My first thought was something electrical. I got it towed to the ramp by a fellow boater and put it on the trailer. I opened up the hatch and looked at everything that could be the culprit. I noticed a washer that was corroded on the neutral safety switch. I removed the star lock washer and the boat fired right up. I later went to the hardware store and the grand total for that fix was a whopping twelve cents...
bobbytheboozer
resident boozer
They tested from the battery.
bobbytheboozer
resident boozer
Hahaha, that's awesome. I'm still a little wiry that something will go wrong, but for now, I'm crossing my fingers
SBMech
Fixes Broken Stuff
This was 100% caused by the installer, and it's doubtful that "vibration" would have loosened it, the moron just forgot to tighten it...:D
So either your stereo guy or the guy who did your steps/lights almost fucked you good...you are lucky as shit it did not fry anything..:eek
bobbytheboozer
resident boozer
Yea, it had to have been the stereo. The steps were on the truck when I bought it.
