DUNEFLYER
The original DUNEFLYER of RDP 😁
- Dec 22, 2008
- 1,081
- 2,808
Whatchu talkin bout Willis. View attachment 1372994
It has to be able to seen 360 degrees. Mine is on top of the rear bimini. 360 degree LED bulb on a 12" stainless poll.
Mine unscrews and is under the back seat until neededSo how do you guys fold up and store you bimini tops then?
“We've never had an issue with speed although we normally cruise at 35 or so. I've never really cared for the arch style. A little too Miami Vice ish for me.”
Ha easy there Crockett, they are talking about the speed on the water not towing to the launch ramp .
Nothing wrong with the square tubing, depending on the gauge. Most I've seen also use aluminum connections with stainless pins, no plastic.View attachment 1373165 View attachment 1373166 My Bimini was built with the same square tubing material that the side rails were built out of. Boat has seen 50mph one time, normal cruise is 40mph, Bimini doesn’t move at all.
Why remove and store it? Fold it down if you have low storage. Honestly no idea , never had a reason to remove the Bimini. I can run it at nearly 60 w zero concernsSo how do you guys fold up and store you bimini tops then?
Mine never leaves the boat. It's either up or folded down on the supports.So how do you guys fold up and store you bimini tops then?
Ya you fold it up put cover on, has cut out where light is. Why you makin this harder then it needs to be, lolI have a cover the whole bimini slips into, nice and tight.
Then it rests on two little 4" poles, so it won't lay in the upholstery, and then the whole boat gets covered.
No indoor storage at Big Bend.
Can you please tell me who built you the bimini?View attachment 1373165 View attachment 1373166 My Bimini was built with the same square tubing material that the side rails were built out of. Boat has seen 50mph one time, normal cruise is 40mph, Bimini doesn’t move at all.
“Trends” may have changed, however I dont think the rules have.That’s the white anchor light.
Rear nav light is just that, rear. Doesn’t have to be seen 360 degrees or that would confuse people. The trend has moved to white light on a short pole at the stern but typically you can’t always see it from dead on.
Its adjustable and simply folds down.So how do you guys fold up and store you bimini tops then?
I wish I could but I have no idea, I bought this boat as is a few years ago. I will look to see if there is a tag or any info on the bimini when I get back up there.Can you please tell me who built you the bimini?
Yep, here are the USCG requirements:“Trends” may have changed, however I dont think the rules have.
“An all-round white light or both a masthead light and a sternlight. These lights must be visible from a distance of at least two miles away on a dark, clear night. The all-round white light (or the masthead light and sternlight) must be visible from all directions in a 360-degree circle.”
