- Aug 28, 2016
- 35,694
- 90,883
What smoker, I can't get a bark like that at 225°Try to hold 225.
I also do the Texas crutch.
I use a small barrel smoker.What smoker, I can't get a bark like that at 225°
I got a great bark with my vertical smoker using charcoal and wood chips but when I restoked the coals the temp would go up to 260-270 and slowly come down. With my GMG it at 225-230 the whole time, I'm going to bump the temp to 260 this Saturday and see how that works. As far as the smoke flavor and smoke ring I use 2 smoke tubes and cold smoke the brisket for 60min before I fire up the smoker and the flavor and ring are perfect.I use a small barrel smoker.
Charcoal and wood chips.
Takes a lot more work but I like the Smoke ring and taste I get versus the Treagers and Propane/Electric smokers I’ve seen.
Tonight’s point meat close up.
Sounds like a great plan!I got a great bark with my vertical smoker using charcoal and wood chips but when I restoked the coals the temp would go up to 260-270 and slowly come down. With my GMG it at 225-230 the whole time, I'm going to bump the temp to 260 this Saturday and see how that works. As far as the smoke flavor and smoke ring I use 2 smoke tubes and cold smoke the brisket for 60min before I fire up the smoker and the flavor and ring are perfect.
What's not to like about ribs?Some 3-2-1 ribs. Never been a fan of ribs. First time ever cooking them. Figured I’d give it a shot. Neighbors seemed to love them.
Its always been the mess for me. I will make these again. Next time I am going to cook them un-sauced and see how I like it (add sauce once they are done if need be).What's not to like about ribs?
321 methodRibs from Memorial weekend. I used a smoking tube with pellets along with the Pit Boss on 225f.
First time doing it on a pellet smoker and I overcooked them. don't think 225 is accurate (even though it has a seperate digital and analog thermometer). I think that because the grate was sizzling pretty much the whole time. I don't remember that ever happening when I did it at an actual 225 offset smoking...
Thanks!! Yours looks even better than mine!321 method
3hrs on the grille
2hrs wrapped in foil (with a little apple juice or grenadine in the foil)
1hr on the grille while applying the glaze
321 will be absolutely fall off the bone,like bones fall out while cutting them.
I do
3hrs on the grille
1.5hrs wrapped
1-1:15 on the grille while glazing
This pulls off the bone perfectly
Both cooked at 225°
If you want more smoke flavor, cold smoke whatever meat you are cooking for an hour to hour and a half with the smoke tube and then turn on the smoker. You can also cold smoke bacon the same way before cooking it.
View attachment 1236901 View attachment 1236902 View attachment 1236903 View attachment 1236904 View attachment 1236905 View attachment 1236906
Get a thermometer that does the meat and the grille temp. Thermoworks or fire board thermometers, that will tell you if the grill temp is close
I'd call Pit Boss and see what they sayThanks!! Yours looks even better than mine!
Funny you mention that. I have a Thermoworks and I didn't use it because it gives me anxiety looking at it all the time lol. But yes, last time I ran it the temp was typically much higher on there than the Pit Boss indicated. 225 was more like 260 (but only occasionaly which drove me nuts). I think there's "hotspots" in the air within the grill.. IDK I think I will try a single rack of ribs just to test at a lower temp like 200 and see. Thx for the reminder. Bottom line is there is no foolproof way to BBQ, you need to pay attention!
Details please
You have the same dog living next door that I do.
We're neighbors?You have the same dog living next door that I do.
I'd know that bark anywhere.We're neighbors?![]()
Yup, we have a 13.77lbs. I'm guessing it will be about 11.5 after trimming. Putting it on at 2am to have it done between 1 and 3 in the afternoon, eating between 4:30 and 5.If you know…YOU KNOW. Happy 4th of July
View attachment 1248785 View attachment 1248786 View attachment 1248787
Vacuum marinated tritip, and homemade baked beans!
Trying out the meat thermometers got for Fathers day. Nice to be able to adjust temp as needed from real time.
Get a Thermapen little spendy but highly accurateWhich thermometer? I need a new one.
Called the "prob T"Which thermometer? I need a new one.
