Strange electrical issues with 14-18 Sierra/Yukon?
DarkHorseRacing
Just putting this here for posterity, in case some inmate goes searching for this later.
I have a 2016 GMC Yukon XL and at about 150,000 miles it started having wonky electrical issues. At first I thought the battery was bad, so I replaced that, but it didnt seem to help anything. So I tried to live with it. Right up until I drove home one night, tried backing into my driveway and suddenly by cranking the steering to lock/limit was able to trigger over a half dozen "Service <this>" messages, including Charging System, Stabilitrack, Steering System, Body Control, etc. In addition to those messages the lights would dim, the gauges and DIC would blip.
Then the next day, I went to start the vehicle and when I got in the vehicle I could see the DIC had power, and the interior lights came on, but when I hit the start button (push start), I got a sudden loud click outside the vehicle and then the vehicle went 100% dead. No power to anything (no lights, chimes, gauges, start button was totally unresponsive, no start noises, NOTHING). So I popped the hood and checked the battery connections and the fuse block, made sure all the relays and fuses were snugly inserted. Wiggled the battery ground seemed to restore the power, so then it was hit or miss if the vehicle started. If it started, it ran, but then the vehicle acted like it had never seen the battery before (despite me not disconnecting the battery in any way) and wanted me to open close windows, etc. If I shut it off, it would sometimes completely die again when I hit the start/stop button.
I thought maybe I had a bad ground so I crawled all over removing, cleaning and reinstalling the ground points on the frame. Seemed to help slightly but was still not 100%. So I found a good article about testing the positive and negative battery cables:
Following the above process with a tester, I tested my positive and negative cables with this method. When they say positive cable they mean the little short cable from the battery positive post to the bus/distribution bar mounted on top of the battery in its own little box.
This method states if the positive cable tests to over 100mV to replace it, and the negative to over 200mV to replace it. Well my positive and negative were both over 500mV! So between these two cables, I was losing over 1V of battery power to the vehicle. Not to mention this is hard on the alternator because it cant properly charge the battery with loss like this.
So I'm replacing both of these battery cables. The positive cable itself is a kit with the battery distribution bus, and the negative cable is a three connection ground (battery, frame and engine). On this site: https://www.gmpartsonline.net/v-201...-and-starting--battery-and-related-components its Items numbered 5 and 7. Item number 9 apparently doesnt go bad like #5, so I dont believe it needs to be changed.
I figure this fix will resolve all my issues. I'll report back after I get this done, but I figure if anyone else with a GM product in this year range is having strange electrical issues, start with this test, and with these results to determine if this is the root of the issues.
Also turns out that GM products older than this range have also had a litany of electrical issues and the underlying cause seems to be a history of bad positive/negative cables, so that is something you should still look into even with an older GM product (as far back as 200-2010+).
DarkHorseRacing
Ok here’s my update after replacing the positive and negative.
Seems fixed.
One way I think that is one of the other odd electrical issues I was having was a slow crank/start of the engine. Push the start button and it was a slow ruh-ruh-ruh-ruh then starting. Now with both cables replaced it fires right up (after a much quicker and only one “ruh”). That was one of the reasons I swapped batteries. I may not have had a bad battery at all. And when I replaced the battery I spent the coin on an Odyssey and it didn’t change anything.
So I have to drive it for awhile and see if this issue pops up again in any way.
Jaxar
New Member
I have a 2018 Yukon SLT and I’ve recently started experiencing the same exact “electrical” issue with mine at 100,000 miles.
Did you also experience the random very loud start-up chiming ?
I’ve went into settings, comfort and convenience, and turned the chime down, but randomly I’ve noticed it more in the mornings that the chime is extremely loud for the first few chimes.
All this started happening around the same time.
Jaxar
New Member
The truck recently went in for its 97,500 mile service and I mentioned all this. They checked the battery and said the battery tested good. They reported no other issues with the vehicle…
DarkHorseRacing
Well i guess I could update this thread.
The issue returned but what I found was the negative ground wasn’t tight and it started doing all the wierd shit like sometimes starting, randomly shutting off, the steering wheel jerking while turning and all the service this messages going off. Torqued the crap out of the negative cable and not an issue since on that.
However I did just have a different issue. Driving just north of Vegas in the construction zone is a bit of rumble strips in the road that you pretty much have to drive on. I spent like 20-30 seconds driving on it and thought nothing of it. Stopped later and when I turned the car back on, had service Adaptive Cruise, service collision warning, service one other I can’t remember. Nothing had changed just kept getting the messages after that. I researched it and was going to try a few things after the trip I’m on. Well it went away on its own. WTH. Clearly not a blown fuse or the radar thing breaking its bracket. So far it’s still working but I gotta drive 12 hours home on Saturday so we’ll see how it goes.
I’m around 165,000 miles at the moment.
My buddies kids truck had this issue.
Positive battery cable fixed it. Defective crimp from the factory.
@lbhsbz
@lbhsbz
Why'd you tag me? I remember posting a picture of a factory GM crimp where they failed to strip the insulation off the battery cable first....lol....and that's why the UAW guys should get more money. fucktards.
Jaxar
New Member
Any of you guys experiencing the very loud start-up chime as well?
DarkHorseRacing
No I am not. But I turned a lot of the noises off. The honking for status, chiming, etc. I live in a very quiet area and no one needs to hear my car constantly honking and chiming.
Thought you might have that pic/info still? No big.
Jaxar
New Member
Everything of mine has been turned down or off. Must be another electrical issue then. Because randomly the chime dings as if the volume was at full max.
boblee63050
New Member
I just started having the same issues on my 2016 Yukon XL SLT. Did the new cables fix your electrical issues permantly? I see this post is a year old or so.
DarkHorseRacing
Yes. Though I did have a later reoccurrence it came down to the battery cables were not as tight to the battery terminal they should have been, and tightening them down again it has not come back.
RustedBl4de
New Member
I have a 2018 Yukon Denali and seem to be having the same problems. When you say “replace the positive battery cable” do you mean the mini cable between battery and distribution block or the cables after the block? Going to go through the tests tomorrow and see if I can resolve the issues. The power distribution block has cracks in the plastic box it is inside of as well.
DarkHorseRacing
Reread my post #1 again. It’s the short red cable plus the distribution block. And the neg cable from the battery to the three locations. One or both should not test over those stated values.
Also torque the crap out of the battery cables on the battery terminals. Not just snug but tight. For some reason tight is necessary.
boblee63050
New Member
Thank You so much for the reply. I appreciate it. I had both cables replaced & so far it seems to be fixed.
bilz
Newly Retired!😁
Great post for you gm'ers.
I passed this on to a buddy.
jamberama
New Member
Hi there, we have a 2016 yukon xl and are currently having all these issues. Could you please tell me exactly what parts I need to replace. The link uptop doesn't work and I got a little confused about the parts you mentioned.
Thanks
Thanks
Replace ALL the battery cables.
jamberama
New Member
Angler
Tritoon Racing
Just another reason to buy a Ford.
16 years old with 195k miles, never had to replace battery cables.
Carry on.
DarkHorseRacing
To update the thread, still a good fix, but then I started having odd issues where the car wouldn't start, and the instrument cluster would go out when I tried to start it. I took it back in to have the starter replaced and that was the other fix. Been solid since.
Maestro
Different vehicle but on the rams we had similar conditions. The tipm (fuse box under the hood would have burned contacts. Pull it out and remove the j connection. And you'll see burn contacts. Also we found that the would put multiple grounds in a single stud. Once we separated the grounds we had less issues.
