Stern light
rivergames
I have a friend looking for a certain type of stern light. Pretty much the whole pole lights up. Needs to be around 36" +
Also I need to know if one of these are legal?
rivergames
just like it.
Needs to have the same mount as most of the stock generic stern lights
BoatCop
Retired And Loving It.
No, they are not legal.
The 360 degree white light needs to be displayed a minimum of 1 meter above the red/green or combination light(s).
rivergames
Thanks for the info Alan. I will tell him to scratch the idea
BoatCop
There are also technical requirements for intensity, color range, and other factors that a light of that confuguration would not comply with.
schiadastan
Hi Allen is it one meter above the bow light or is it the highest part of the boat? I thot coast gaurd said the boat?????
Thanks
Stan
FASTJTBT144
Now are the flush rear transom legal for inter waters only? I had heard that a long time ago that there not C G approved unless a pole type is used?
BoatCop
Thanks
Stan
1 meter above the red/green bow or side lights:
"ANNEX I?Continued
(d) A power-driven vessel of less than 12 meters in length may carry the
uppermost light at a height of less than 2.5 meters above the gunwale.
When, however, a masthead light is carried in addition to sidelights and
a sternlight or the all-round light prescribed in rule 23(c)(i) is carried in
addition to sidelights, then such masthead light or allround light shall be
carried at least 1 meter higher than the sidelights.
The transom light, when used by itself or with red/green bow lights is NOT legal on either inland or international waters.
A transom or stern light, showing an arc of 135 degrees must be used in conjunction with a masthead light, showing forward in an arc of 225 degrees. The two lights together make up the required 360 degree all-around white light. The masthead light has to be a minimum of 1 meter above the red/green liughts, as above.
This isn't to be confused with a 360 degree all-around anchor light, which must be from a single lamp, or 2 lamps situated so close to each other to be viewed as a single lamp, from a distance of 1 mile.
In any case, the white light(s) must be visible for 2 miles and the red/green bow or side lights must be visible for 1 mile.
djunkie
Broke mo fo
Hey Alan. I have a 360* light on a pole that I added to my Schiada and it also has the old school 180* transom mounted one. I know the 360* one is legal but should I disconnect the transom one? They both work right now. Or is it ok to have them both on?
harlanorrin
I BUILT A HYDROLANE THAT RAN SUCTION CUP LIGHTS ON THE DECK AT THE BOW AND ON TOP OF THE CARB SCOOP. WOULD THESE BE LEGAL????????
HARLAN ORRIN
BoatCop
Technically illegal, but I don't think anyone will say anything. There may be some overzealous watercop that may take issue with it, so to avoid being conspicuous, it might be best to just pull the bulb. The Coast Guard will most definitely stop you for it.
HARLAN ORRIN
As long as the lights are visible for the required distance and the suction cup light on top of the carb isn't blocked by people in the boat, you'd be OK.
Keep in mind, that after about an hour, the batteries weaken and the lights go dim. Carry an extra set or two of batteries with you and change them if the lights start to fade.
Also realize that the batteries you put in them last year (or even last month) probably aren't going to help you get from Roadrunner to the camp when the sun goes down. If you even THINK you might be out close to sunset, have a new set available before you go out.
schiadastan
THANKS ALLEN
Jet-Daytona
"ANNEX I?Continued
Where the Light is 8' + above?
BoatCop
There's no maximum height above.
If you're refering to the "Stick" light that rivergames first asked about, that light starts at the mount, and doesn't meet the technical requirements for navigation lights.
BoatWhipz
I know this is a super old thread 🤙🏼
BoatWhipz.com has what you need, we offer the only patented and US Coast Guard Approved LED Color changing stern light. In stock now and underwater lights as well 👍🏼
