Dirtbag
- Aug 24, 2016
- 3,278
- 5,189
For those with Solar How do you clean your panels? Do you use a service? How often do you clean them? We are 1 year in owning Solar and they are pretty dusty
So, you won't be applying for the Secret Service?I have mine set to be done annually. Guy has a Deionized water system in his truck, uses my water with a spinning brush attachment to a hose. Gives them a good scrub then squeegee dry. I think I have 20 panels on a pretty steep pitch and I pay $350
I also am the pool guy, landscaper, oil changer but one thing I don't do is heights, extension ladders, and roof's mixed with water up there.
That was a question I was going to ask,You are not going to gain the money back spending 350 cleaning panels...
Here is your answer, first spray with water only, brush if needed. Dont recommend chemicals, soft soap if any at most.I get on the roof at least twice a year with hose,pool brush pole with rag wrapped around brush…scrub as much bird shit or whatever has stuck on hose off and use a dry towel to finish. Seems to make a big difference when there clean.
But I also maintain our pool,landscape,vehicle oil changes and etc. a lot of people just sit back make a phone call pay for everything.
Correct,no chemicals just a easy scrub to remove the caked on bird shit..were in Agua Dulce outside of Santa Clarita with acreage and with the dust collection during the spring/summer and zero to little rain I feel it’s worth taking the 30 or so minutes and clean the 40 panels.Here is your answer, first spray with water only, brush if needed. Dont recommend chemicals, soft soap if any at most.
Yeah, but that also includes trampling your roof tiles.Damn $350 to wash some panels. You guys are crazy.
Your house in Murrieta? 2 story? If so, I need that guys number.Have a company come out every 6 months. $100
This is all that should ever be done… no abrasives, no brushes, and most of all no waxes, coatings like rainx etc…Windex and Zep both make a window cleaner hose attachment that works really well. Suds them up and rinse them off. Quick , easy and does a great job.
So, if your summer bills add up to $5k, 3% is $150. Not worth it for a $350 cleaning, is it?Damn, I'm getting a great deal then.
My window cleaner charges me $ 450, but that includes a shit-ton of inside and outside of all the two story house windows included.
I get my 26 panels done once in the summer, they stay fairly clean over winter with the occasional rain. One time I checked before and after a summer cleaning, made about a 3% difference.
The panel cleaning is around $100, the cost of the window cleaning is $350.So, if your summer bills add up to $5k, 3% is $150. Not worth it for a $350 cleaning, is it?
Na, it only builds up so much before it washes off in the rain.The panel cleaning is around $100, the cost of the window cleaning is $350.
Without a good annual cleaning the dust and bee shit accumulation would be far more extensive. Between that and a few good winter downpours, that program has worked for us for the past 14 years. Good enough we've never owed for an electric bill since building this 3600sf all electric home.
Not even a dedicated soft brittle, car wash brush and a little Simple Green?This is all that should ever be done… no abrasives, no brushes, and most of all no waxes, coatings like rainx etc…
if the "solar panel cleaner" shows up with a power washer don't even let them get started... welcome to blown out seals, water intrusion and voided warranties for the inevitable failure/panel arc'ing
If you’re going to use Simple Green get the aircraft friendly version. The regular will etch the aluminum fram work.Not even a dedicated soft brittle, car wash brush and a little Simple Green?
My situation isnt about production issues as much as it’s about the appearance of my panels. For now, I can see them from the street when we drive by. I’ve planted some multi branch pepper trees to block the view but we’re a few years from blocking them. I hate seeing them dirty (OCD maybe?). Between the neighbors horses and my tractor and truck, propane delivery, etc all driving on the easement next the panels, they get dusty and dirty quickly.
Thanks,Na, it only builds up so much before it washes off in the rain.
Couple of things though. Does your module cleaner cover you if they damage a module? Also, you want to avoid getting them wet if fey are really hot, could cause them to crack.
PV is surprisingly tolerant of dust and surprisingly intolerant of obstructions.
I use it sparingly. It cuts through the oak tree pollen that gets everywhere. I also have the same bird/owl/crow problem stated above. I usually find acorns and crap like that on my panels.If you’re going to use Simple Green get the aircraft friendly version. The regular will etch the aluminum fram work.
