FreeBird236
- Apr 21, 2012
- 13,992
- 13,320
Hey Eric, How's the food at the Mississippi Pub?
Since we all know I'm not a bot now (thanks to Jerry Hovet's research) I can show my Electrical Engineer's chops and provide ya'll another example from ABYC.
If you use the 'base map' tables from ABYC E-11 to choose the gauge and insulation temperature rating of boat wiring, you will be wasting money 90% of the time, but the calculations you need to do compute an economically optimal gauge of wire are beyond the capabilities of electricians who are not electrical engineers. The tables in ABYC E-11 are safe 'starting values' but almost always result in oversized wiring.
Anybody want to see the tables and/or the calculations that can be used to save money on copper? Copper has gotten REALLY expensive lately...
Interesting (and last) thing I'll note before I leave this thread...did anyone here ask you about your "Use Case" i.e. "what problem are you trying to solve?"
On my river high octane marine gas is increasingly hard to find and none of our boats ever go on trailers. There are at least 15 river miles between marina gas docks so we have to deal with everything from 87 to 92 octane on any given day. So the #1 reason to upgrade IMO is to get automatic spark retard/advance from a 'knock sensor' signal feeding a MEFI to enable "Octane Adapt". Some of the newer carbuerated engines have knock-sensors but when you don't, an EFI upgrade is one way to do it (assuming the system has an input for a knock sensor).
Good luck with your decision.
Seriously? 15 milliseconds was the response time was back in the 1980s, much faster now. More than fast enough and so sensitive it can hear the knock even when the engine roar drowns it out. But if you have a better faster way to retard spark when your engine starts knocking, please share...By the time the knock sensor on an MEFI computer goes off, it’s too late. What a joke if you think a knock sensor is protecting the motor and changing parameters enough to safeguard an engine, What a joke.
Tell me you don’t build or tune engines, without telling me you don’t built or tune engines…Seriously? 15 milliseconds was the response time was back in the 1980s, much faster now. More than fast enough and so sensitive it can hear the knock even when the engine roar drowns it out. But if you have a better faster way to retard spark when your engine starts knocking, please share...
Whoops, sorry Paul. It's been suggested to me that I should use simpler language for my explanations. The term 'millisecond' means thousandths of a second. At 4,000 RPM there are 4000/60sec/minute=66.7 revolutions per second, and that is 14.99 milliseconds per revolution, and since the knock sensor will 'hear' a knock in 5ms (1/3rd of a revolution) and respond faster than once per revolution, I'm not sure how much faster it would need to be? If pre-ignition can happen only once per cylinder-per rev (worst case) how fast do you think it should be? Microseconds?Seriously? 15 milliseconds was the response time was back in the 1980s, much faster now. More than fast enough and so sensitive it can hear the knock even when the engine roar drowns it out. But if you have a better faster way to retard spark when your engine starts knocking, please share...
Ok @Bigbore500r -- From the 1980's. Look, no Tables! And please don't call me Jesus...No, but riddle me this oh mysterious one - where does your MEFI get its spark advance values from? A crystal ball? Jesus? It uses a table, just like when it determines fueling .
You’re gonna dig this hole to China …. Unfortunately you’ll discover they use tables in their EFI programs too
I'm sorry, I don't know that. Try asking a different way. (LoL, I'm a bot, remember?)Hey Eric, How's the food at the Mississippi Pub?
Thanks, but I checked it out and there are smarter people than me ( @paradise and @92562) who seem to be dealing with the problem there quite effectively.We need @ElectroNautical to go over and assert his dominant knowledge in the moon landing thread.
No, 'dude' not magic and no need to invoke the Almighty. Just Moore's Law circa 1986....which appears to somehow be a 'Wow' moment for you. Lotsa 'Digital Dotardry' in your posts, eh? And OBTW, even magic powers can't predict when you'll need to retard spark after putting low-octane fuel into a high compression engine. Someone or something needs to detect a knock first right? If 15 milliseconds (in 1986) wasn't fast enough, who or what is? You? God? Biff Tannen?Omg dude you can't be serious.... Wow.
The mefi has magic powers that can snuff out the charge after detonation and knock have already happened
That said, I'm sure it is not as good as Martini BayI'm sorry, I don't know that. Try asking a different way. (LoL, I'm a bot, remember?)
I'm sorry I wouldn't know, never heard of it.That said, I'm sure it is not as good as Martini Bay
Yep. Not to mention, they pull way more timing than is necessary when knock is detected, then the decay rate in stock EFI programs is so slow to feed timing back in the motor loses a ton of power and falls on its face. All bad shit if it's happening constantly., like a roller coaster under sustained load. The knock sensors are there as a safety net here and there, and to stop massive detonation events due to poor fuel, etc. They are not for constant timing sweeps to determine max advance in real time. Relying on knock sensors to set and adjust the engines spark advance is absolute ......... "retardation"Complete cycle time at 5000 is 24 mSec, so 8 firing events happen every 24 mSec. That means you are gonna deliver the same fueling and spark to at least 3, if not 4 additional cylinders before any action is taken...
Even if it responds immediately after the 5 mSec knock duration window you are definitely sending the same timing to the next cylinder as it's already fired. And the cylinder after that has almost certainly began the dwell charge for its coil which you can't stop early so it's going too...
This is why you can't rely on closed loop knock control for anything other than a mild stock motor. Shit will already be breaking if the motor is making any substantial power.
yes. how many times does the injector fire for that same scenario at 6k rpm? the bot would answer.At 6k RPM...
The exhaust valve will open/close FIFTY times per second.
Kinna crazy to think about.
I gave an example from a 'mild stock' 1986 Buick V6 that redlines at 4,200rpm to illustrate the principle, in the context of 'why upgrade from carb to efi'.Complete cycle time at 5000 is 24 mSec, so 8 firing events happen every 24 mSec. That means you aregonna deliver the same fueling and spark to at least 3, if not 4 additional cylinders before any action is taken...
Even if it responds immediately after the5 mSec knock duration windowyou aredefinitely sending the same timing to the next cylinder as it's already fired. And the cylinder after that has almost certainly began the dwell charge for its coilwhich you can't stop earlyso it's going too...
Did you find it?I gave an example from a 'mild stock' 1986 Buick V6 that redlines at 4,200rpm to illustrate the principle, in the context of 'why upgrade from carb to efi'.
You've used the numbers from a 1986 V6 system to make your point, applied those numbers to a 5,000 rpm V8, and so all you've written is garbarge. GI-GO.
Like I said, you need to pay more attention to silicon advancements and rely less on what you once learned from systems that were designed forty years ago.
There have been at least four enhancements to Knock Sensor systems that reduce response times to microseconds and all of them were in MEFI-4 by 2001. Can you tell us what even ONE of them is?
I've uploaded the answers to the cloud share I provided you previously...
"One does not need to be old to be a dotard...one only needs to stop learning."
-unattributed.
-unattributed.
Don't have to, been running that way for 21 years now, on three different boats.Lol you go right ahead and hook your 'real time' MEFI up to knock sensors, no O2 sensors, and let it's magical 'self adjusting' powers keep the engine alive
-unattributed.
The problem is that the 3 or 4 you are referring to are all masterful when it comes to the shiny spinning metal bits and the 'dude' (bot) knows about the silicon bits also, which gives him an advantage. Think about metallurgy for a minute...have their been any major advances in combustion engine metallurgy in the last 20 years that have made as much difference as the electronics have? Valve springs? Nope. Bearings? Nope. Cast Iron? Nope. Forged or Billet pistons? Nope. If there have been any game-changing advancements, I'm sure @Racey or @DaveH or others could tell us all about them.This thread is nutz! 3 or 4 of RDP's most respected and knowledge people vs some dude that stumbled in here wearing a gold chain. I wish we could get Shan to do a fly by.
Show me your silicone bits!The problem is that the 3 or 4 you are referring to are all masterful when it comes to the shiny spinning metal bits and the 'dude' (bot) knows about the silicon bits also, which gives him an advantage. Think about metallurgy for a minute...have their been any major advances in combustion engine metallurgy in the last 20 years that have made as much difference as the electronics have? Valve springs? Nope. Bearings? Nope. Cast Iron? Nope. Forged or Billet pistons? Nope. If there have been any game-changing advancements, I'm sure @Racey or @DaveH or others could tell us all about them.
Probably the only metallurgical advance worth noting is 'lost foam' casting that allowed aluminum engine blocks to take on complex internal shapes and reduced the weight of 4-stroke gasoline engines used in cars, but unless I missed it none of the '3 or 4' are using them in boats. The engine blocks they build on are 25 year old technology, or older.
The 'discussions' on manual tuning of LUTs vs Real-Time computation illustrate my point. If you don't understand silicon advancements (Moore's Law, etc.) you can't possibly appreciate how important they have been or why they work so differently (and so much better) than before.
I didn't come here to make anyone feel stupid, but given all the rude and dismissive crap and the personal attacks...well lets just say 'elbows will fly'. I always give as good as I get...at a minimum.
You won't find it because it doesn't exist, you are nothing but a trollThe problem is that the 3 or 4 you are referring to are all masterful when it comes to the shiny spinning metal bits and the 'dude' (bot) knows about the silicon bits also, which gives him an advantage. Think about metallurgy for a minute...have their been any major advances in combustion engine metallurgy in the last 20 years that have made as much difference as the electronics have? Valve springs? Nope. Bearings? Nope. Cast Iron? Nope. Forged or Billet pistons? Nope. If there have been any game-changing advancements, I'm sure @Racey or @DaveH or others could tell us all about them.
Your wrong on everything you just posted, which is a consistent pattern at least…
There are many cutting edge engines developed specifically for boats over the past 25 years, incorporating major design advancements in everything you just posted. Merc QC4V, 500hp Merc outboards, Illmore MV570 - pick your poison. They all use tables in their programming too….
You understand neither side of the spectrum - mechanical or engine management. The advice and info your posting is baseless garbage that’s gonna blow somebodies engine up if they followed it.
You came in spreading mass disinformation as a self-proclaimed guru. You immediately started attacking members, posting strange theories about their livelyhoods, their family ties, even stating that River Dave will know who you are and can vouch for some of this nonsense .
Personally - I can’t stand to see people get burned by bad advice, so yea - I called you out, and continue to do so. I hope you don’t turn a wrench on anyone’s boat where your at.
Im still hoping you’re a bot, mainly because I can’t believe how sideways your replies can get. It’s like a Charles Manson interview mixed with an old episode of Horsepower TV
Imagine this forum being a large fully catered backyard gathering in a very nice neighborhood.
It’s a party of friends/families who have known each other for years.
Now imagine you’re the neighbor friend of maybe a month or two who shows up because you had a loose invite based on common interests.
All of a sudden you come barreling into the backyard party and start complaining to everyone, who you don’t know, about the shitty free food and how you don’t like the beer and how you don’t like the music and on and on.
The core group is like… who shit in this guys cheerios…?
Then you’re upset and accusatory because nobody knows who the fuck you are and your telling the host (RD) not to tell the partygoers who you are. You appear to have a shitty attitude based on your behavior and you act like everyone should embrace you because you think you can throw a better gathering than anyone else.
Basically you’re a party crasher. Pump your fucking brakes and learn to have a discussion and interact and socialize with people.
Learn how the written word and inflection works.
Don’t shit on our party and pretend the party you throw is better. That’s how forums work. Know your audience.
I truly can't understand why you are still here......The problem is that the 3 or 4 you are referring to are all masterful when it comes to the shiny spinning metal bits and the 'dude' (bot) knows about the silicon bits also, which gives him an advantage. Think about metallurgy for a minute...have their been any major advances in combustion engine metallurgy in the last 20 years that have made as much difference as the electronics have? Valve springs? Nope. Bearings? Nope. Cast Iron? Nope. Forged or Billet pistons? Nope. If there have been any game-changing advancements, I'm sure @Racey or @DaveH or others could tell us all about them.
I go back and forth….Don’t ya still thinking it’s a bot?
Uninformed maybe but not a bot?
I have no idea who this person is.. I read his post though and while I can see how someone could jump to that conclusion that isn’t what it said.
Whatever we call it the thing is weird AF, creepy.
Nope. Thing thing definately has not evolvedIt reminds me of when forums First became a thing...
The main goal was to "one up" everyone else. Ridiculous arguments that would go off in every direction, except what the original topic was about!
My dad can kick your dad's ass. Dick measuring contests. I'm right and you're wrong. Just Stupid childish bullshit!
Clearly thing thing hasn't evolved yet.
It's the Cro-Magnon man of modern social media.
Question for @Bigbore500r @Racey @DaveH
Let's say you're setting up a new engine or an existing engine that has undergone multiple upgrades and needs a complete re tune, I dont think application matters here, boat, sandcar, truck whatever.
You're doing your tuning work in August, but the engine will likely be used in January, or a higher altitude or any number of environmental differences. Do you need to wait until January to continue your work? Does the engine / vehicle need to be present in each of these environment scenarios for a proper tune? Or can you apply data from one scenario to another with some math or conversion? How would you go about it?
Back on the Knock sensor topic, just trying to square what i'm reading with what I thought I understood.
According to Ford, The 2024 Ford Bronco's 2.3-liter EcoBoost® 4-cylinder engine produces 300 horsepower and 325 pound-feet of torque with premium fuel. With regular gas, the engine produces 275 horsepower and 315 pound-feet of torque.
The explanation for how this is done: Ford's EcoBoost 2.3 engine uses a calculation called the Octane Adjust Ratio (OAR) to detect the octane of the fuel being used. The OAR is adjusted based on whether the engine detects detonation, and over time the computer learns the octane level of the fuel. The OAR is fully adjusted for higher power at -1.0, and fully retarded at 1.0.
Using this type of spark advance / knock retard logic that your stock Ecoboost uses is fine for OEM stock vehicles. The tune is very conservative, and they need to be able to cope with shit gas that you might encounter in the middle of nowhere. When it detects a pattern of detonation, or unacceptable levels of detonation, it reverts to a low octane spark table that is more conservative, so its not just “bouncing off” the knock sensors and advancing / retarding against detonation.Back on the Knock sensor topic, just trying to square what i'm reading with what I thought I understood.
I'm not sure how the new Ford ecm tables are structured on their late model stuff, but GM stuff uses 2 different spark tables, depending on octane. If it detects knock above a certain threshold / consistency, it will revert to the low octane table and stay there and operate. It will attempt to advance timing and "test" against the table every so often, to see if it can get away with more timing. If it is successful in reverting back to the high octane spark values, it will revert to running from the high-octane table after the parameters are met (how many times was it successful in running from the high-octane table, how long has it been since it detected detonation using high octane table, etc . . .)
It's different than just running too much timing, and consistently relying on the motor running "on" the knock sensor's command to retard timing. all the time.
A "ping" here and there with a stock motor is one thing, but a performance motor hammering away against the knock sensors and going "ping PING PING - Retard. . . . ping PING....retard" is super hard on stuff and like Racey said in another post, is real hard on both pistons, and exhaust valves.
Knock sensors in a performance application are best used as a tuning aid, and a last ditch safety net for when shit goes wrong - not something you want to rely on for constant spark control under load, especially WOT.
Even if it is in "CONTROLLED IN REAL TIME BY MEFI”
When the GM stuff is tuned for a performance application, here's the basic steps done to keep the motor from relying on the knock sensors, and to get timing in a safe range:
- Low octane spark table is changed to match the high octane spark table (basically, eliminating this variable for tuning)
- The vehicle is ran thru different driving conditions, and the knock retard is logged via a histogram that mimics the layout of the main spark table
- Once enough reliable data has been collected under different conditions, the histogram will show the cells that experienced knock retard, and the average amount of timing that was pulled to eliminate detonation. Looks like this:
- View attachment 1375133
- The histogram table then gets "copy / pasted" over the main spark tables and applied as a modifier to the existing values, in the cells (cylinder air mass and RPM) that were an issue. For example - At 4000rpm, under a Cylinder air mass of 0.54 g/cyl, timing would be reduced by 0.4 degrees.
- The car is ran and logged again, until the knock retard histogram is acceptable. It's normal to pick up a small ping here and there, and the table I pasted above is very mild. But when you see knock all over the map, and its having to pull alot of timing - that needs to be fixed.
- When starting fresh with a performance engine, the spark tables are set conservative, and then you "creep up" on the sweet spot. You don't want to data log the car, see a shitload of knock, and then work backwards and reduce timing. Sometimes, the Grim Reaper only knocks once . . .
Hahaha....yea it's gnarly to look at when you first crack it open. Theres alot of tables that exist, but don't need to be changed because the scenarios they deal with aren't encountered, or don't need to be altered.I remember the first time I looked at a HP Tuner, and all the various tables in there...
What about different temperatures? What about extended hill climbs? What about elevation? What about what gear you are in? What about towing/load control? What about shit you didn't even think about, until you looked at all those fucking tables!!! Fuck!!!
You change one thing in one table, and it affects 40 different tables that relate to that table. One mis-step, and goodbye engine.
Fuck that nonsense...
Gimme a carb, a box of jets, a drill set, and some power valves, some distributor springs, and I'm good.
You can make a mess of stuff in a hurry though, and make a bad carb seem like a sewing machine
