beerrun
- May 25, 2010
- 4,869
- 9,818
Anyone have an idea where I can find 4 used pots?
A smudge pot boiled over in my buddies pit this past weekend in Phoenix and almost burned down his whole Race trailer and race boat! Be careful
Burning oil?? Moisture is bad for them. I’ve used smudge pots for 15 years only had one boil and was burning oil.A smudge pot boiled over in my buddies pit this past weekend in Phoenix and almost burned down his whole Race trailer and race boat! Be careful
Go on ig look up smudgepotusa he sells used ones and inspects them thoroughly sent a few there who were pretty happy.Thanks don't really want to spend 300.00 per pot
How does this happen, i've been running these things for a decade now and have never heard or seen anything like this potentially happening. (and we've done some super sketchy shit with these things. Leaf blower in the intake makes for some action)
Yup. I heard the oil burned over the top and lit up the asphaltBurning oil?? Moisture is bad for them. I’ve used smudge pots for 15 years only had one boil and was burning oil.
Use mine weekly in winter and stick to straight gas and camping I’ll mix some diesel in as it burns longer.
IMO oil sucks I know a few use it. Yes it can burn good but it’s just makes a mess inside with sludge and smells like shit when you shut it off. Then again the moisture in oil can cause boils or even if it gets burning to hot.I heard the oil boiled over. I wasn't there, but it burned a few chairs and real close to their awning. Flames were 30' high.
I burn red dye dieselIMO oil sucks I know a few use it. Yes it can burn good but it’s just makes a mess inside with sludge and smells like shit when you shut it off. Then again the moisture in oil can cause boils or even if it gets burning to hot.
Why I stick to gas or diesel. And gas burns clean and safe and easy to light up with some common sense.
This happened to me once, it was operator error. The pot was kicking ass then it started to slow down and soon after it was like molten lava pouring out of it. I'm sure what happened was there was some residual water left over in the pot after cleaning it out and it started to boil. What a messA smudge pot boiled over in my buddies pit this past weekend in Phoenix and almost burned down his whole Race trailer and race boat! Be careful
Mine did it once because water got in the potHow does this happen, i've been running these things for a decade now and have never heard or seen anything like this potentially happening. (and we've done some super sketchy shit with these things. Leaf blower in the intake makes for some action)
This makes sense, water is heavier and sinks to the bottom, bottom of the pot takes the longest to get hot (farthest away from combustion), water vapor has to boil through hotter and hotter oil as it rises toward that combustion (and oil has a much higher boiling point than the water which will create violent boiling) leading to greater and greater expansion as it climbs through that progressively hotter oil....Mine did it once because water got in the pot
This makes sense, water is heavier and sinks to the bottom, bottom of the pot takes the longest to get hot, water vapor has to boil through hotter and hotter oil, which has a much higher boiling point, as it climbs leading to greater and greater expansion....
Gasoline has a much lower boiling point so the water trapped in the bottom can never boil in a gas
I had a buddy put his cooking oil in his after thanksgiving dinner and it boiled over and shooting out like a volcano to.i believe it was from the water from the turkeysThis makes sense, water is heavier and sinks to the bottom, bottom of the pot takes the longest to get hot, water vapor has to boil through hotter and hotter oil, which has a much higher boiling point, as it climbs leading to greater and greater expansion....
Gasoline has a much lower boiling point so the water trapped in the bottom can never boil in a gas pot.
I’ve left mine out in rain.went to bed and it suddenly rained. But anyhow like said I’ll burn gas mostly and next night I heard crackle and pop I closed holes and let it burn slower never boiled out though. Just kept it low and it was fine.This makes sense, water is heavier and sinks to the bottom, bottom of the pot takes the longest to get hot, water vapor has to boil through hotter and hotter oil, which has a much higher boiling point, as it climbs leading to greater and greater expansion....
On instagram. If you dont have that let me know and ill get his phone number. Ive bought from him.Anyone have an idea where I can find 4 used pots?
I do not have IGOn instagram. If you dont have that let me know and ill get his phone number. Ive bought from him.
Here is his number. 909 702-6995I do not have IG
I know a guy in Rialto caFunny you posted this up! I could use 1 or 2 of them too! I thought someone down in Temecula had them here on RDP for sale.
If we find a seller, and the pots are in decent or better condition, I would like 2 of them if possible.![]()
I know a guy in Rialto caI would take one or two as well.
Thanks really don't want to spend 300. Each![]()
Smudge Pots for Sale | Smudge Pot Direct
If you are looking for smudge pots for sale before your next camping or hunting expedition, check out Smudge Pot Direct for the best prices.smudgepotdirect.com
These are built better then the old units and don’t have to worry about having holes in the bottom like the old ones.
If you have old ones and the bottoms have holes they also sell brand new bottoms for
Them as well.
I does include free shipping, instructions on how not to burn your race pit down, and a warranty.Thanks really don't want to spend 300. Each
He’s the guy I referred too also best one to buy used pots from.Here is his number. 909 702-6995
I would text first. He is in Rialto. Tell him Ron Bierma gave you his number.
Can I ask what you paidJust picked one up from smudge pot USA. Great guy, was in great shape.
You would want to make sure someone has gone through all of them. Otherwise they have pin holes in the bottom and all kinda of build up so they stink. Its worth buying ones that have been pulled apart, cleaned and inspected. If they havent been you need to buy several more then you need so you have parts.How many people would want a smudge pot? I think i found a bunch in nor cal i would be willing to drive up and get them if we could make it worth the trip. I wanted 4 and I see two other people maybe wanted 2 each is that all?
Sent you a message.Can I ask what you paid
Does anyone sell new ones
