RG thank you for the compliments. My glass work is marginal at best but I feel I will get better the more I do it. And with this project, there will be plenty more to do!
You should glass the bulkhead in yourself. It isn't difficult and if you take your time and think everything through, you will be fine. It isn't that difficult my friend. I will be replacing a lot of components (Structural and non-structural), in this hull but I'm not sure if I will be at that point before you. You may beat me to it and I will have to take notes from you.
My recommendation would be to try to "Work neatly" to both minimize the mess/cleanup, but also have a nicer finished product.
RB, I really appreciate the compliments. Thank you for the input!
I enjoy the photos and the lengthy posts. I'm sure some get tired of it but that's OK. I'm hoping people will see my mistakes and errors and learn what not to do. And I'm hoping more knowledgeable veterans can correct me or point me in the right direction along the way. I'm here to help but also to learn. ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As far as supporting the hull, I would highly recommend it. The more support you can give the hull before you remove any structural components, the better off you will be. And you are correct. I would remove the stringers one at a time if you can. The more support the better.
My little Baby has four stringers and the hull is laid up fairly thick. So I felt comfortable removing the two outer stringers and leaving the two inner stringers to support the hull. (It's also resting on the bunks of a cruddy trailer which helps.) When I get to cutting out the two main stringers, I may do those one at a time. We shall see.
As always, thank you guys for following along and for helping out. Enjoy the rest of the weekend!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Henry
Henry
