RV rooftop inverter AC upgrade
mesquito_creek
Has anyone converted their old Coleman style 12-15000 btu RV AC to a new “inverter” AC/heatpump like the Turbro 13.5. Basically mini split tech (variable speed compressor) in a rooftop direct replacement?
Hopefully a review that includes the 115 degree summer heat.
What's the amp draw on the new style?
Seems the biggest problem along the strip is the power supply. Most can't run 3 units off a pedestal. If you could run 3 of the new ones instead of 2. Might be the way to go.
mesquito_creek
I watched a YouTube where a unit drew 400-1100 watts as it varied the speeds. Compare that to my airxcel Coleman 15btu that pulls 1600-1800 watts during a cooling cycle.
But I need some real world desert heat experiences before I would convert.
Maestro
the trailer I'm renting has this done. but they are running off a 110 outlet for the split while the rest of the trailer is setup for 30Amp. Basically set it up for cattail cove since the park is primarily 30 amp hookup. I wont have feed back untillJuly, but in theory this is gonna be a cold trailer...
DoughBallin14
I have seen a couple youtube videos on that model and also a few of the new furrion 18k btu inverter ac never check price difference on the models but another option to look at
