- Jan 11, 2010
- 12,998
- 33,438
@Taboma @rrrr
My Dad's place....he noticed a few days ago that every time the furnace blower turned on, all the lights flickered. Did a bit of digging and is seeing (static) 123V and 117V respectively on each leg coming into the panel, measured at the feed conductors.
Also measured at the feed conductors....any time any load is turned on (coffee maker, FAU, etc...) that leg drops to 104-105V, and the other leg goes up to 130V momentarily before things stabilize.
It's an old Zinsco panel....but based on the fact that voltage is being read BEFORE the main breaker (but after the meter)...I can't see how that would have any sort of an effect on what he's seeing...unless maybe the smart meter is getting dumb somehow.
WTF is happening? I can't imagine a voltage drop through a 2G or whatever feed conductor with such a remedial load as a coffee maker, and that also wouldn't (shouldn't?) have any effect on the other leg that's gaining 7 or so volts while all this is happening.
I told him to call Edison...figure some of their gear on the pole is janky.
