If i were to buy a complete set up id go pci.I keep a baofeng in my buggy if needed takes 5 seconds to program a channel in it manually only cost 26 bucks.Same radio rugged sells marked up since they put the channels in it for you.
My uncles use to be into ham radios in the late 80s early 90s.they used handheld yaesus and kenwoods too but they use to talke from oc to san gabriel valley to santa clarita using repeaters.They also used handhelds in car but external antennas they had no problem talking miles away with only 5 watts,My uncle told me antenna set up is more important than just a higher wattage with crap antennaThe best set up is a cross banding / dual band mounted to your vehicle... Your 5 watt handhelds talk to your vehicle radio and your vehicle radio cross bands that up to the vehicle mounted antenna at 50-60 watts or so.
Radio watts really isn't as important as antenna tuning, placement and line of sight. I have hit a repeaters 50-60 nautical miles away with a 5 watt baofeng on a 30 foot antenna.
The people with "race radios" are normally working in about a 100 yard distance on 75 watts overblasting each other and can't figure out why their radios don't work.
Using a "race radio" outside of a sanctioned event is just as illegal as using a modified amateur VHF on the commercial spectrum, so you are technically in violation of FCC rules either way.
I prefer my Yaesus over my Kenwoods or my Alincos....
Anybody have an alternative to buying cables from RR or PCI?
I have a wired helmet and a hand held radio and want to use them on my motorcycle.
$180. for the two cables. One hooks to the helmet, one push to talk.
At this point I'm over it, hand signals are way cheaper...
Digital coded squelch can be your friend...
are you talking about setting a tone to 88.5 Hz or tune the ctcss to 88.5 for each channel.
I have handheld baofengs which work great. Installed a full rugged setup on my prerunner. The only real difference I see between pci and rugged is pci has better sound quality. I do like that rigged you can tune the stations. But have heard that has changed with the new radios.
English please.Personally I hope everyone stays on the Rugged/PCI radio train... I can't imagine all those donkeys crowding out the what spectrum is available outside of the narrow commercial band afforded to the "race radio".
But if you do the homework, you can outperform it for a fraction of the price. I run an alinco dual band in cross band as my base station at base camp at my house. All the handheld talk to the base in UHF and the base broadcasts in VHF to the mobile units. Yaesu 2900 are in my prerunnners/toys etc....
I run dual band Yaesu 8800 in my regular trucks/tow unit etc.. allows me to monitor something like the weatherman and participate in my talk group on the other band. I also use it as a mobile cross band repeater when needed.
I have a handheld alinco dual band that cross bands also... its nice at Powell in a canyon to hike up and set up a cross bander for the house boat to the play boats...
... and I have spent way to much time on building my own antennas, tuning antennas, dropping baofengs into the river... Burning up radios over powering and over TX to melt down etc...
English please.
English please.
English please.
Great thread guys !!
A lot of Antenna talk, but I'm really curious either how period, or how well, these fractional wave ground plane antennas are working on an SXS with non-metallic roofs ?
Are you bonding to the chassis and using it (Roll cage etc) as the ground reference ?
