Power dolly
beerrun
Anyone have one? Recommendations? Good and the bad?
SkyDirtWaterguy
I just ordered the Parkit360 10k trailer dolley. I’ll report back when I get it and use it a few times
Looks priced right.
DMF
I have this exact unit. I love it. It works great for my needs.
Mikes56
I have the Powercaster and love it. It’s the biggest one that make and it pulls/pushes my 28’ Topcat in and out of the garage with ease.
Mikes56
I forgot to mention that I did change the way the Powercaster attaches to my boat trailer. I didn't want the ugly post looking thing hanging off the bottom of the tongue of my nice boat trailer. I would have had to either weld it on or drill three holes into the tongue area and bolt it in place. Neither of those options sounded good to me.
I contacted Parkit and bought their ball mount and bought a piece of thin wall aluminum tubing and used it for a bearing surface/shim for my Powercaster. Someone on this Forum did send me a surge brake lockout device, which I am still grateful for.
I can take pictures if anyone wants to see what I did.
On my flatbed trailer that I use to haul my SxS I just used the Powercaster mount. That trailer isn’t particularly nice to look at anyways.
ramos45
Powercaster PC3, the biggest one that make. This moved my 34ft scarab 12k lbs fine on driveway and hard pack dirt yard
ramos45
Please post a pic of your setup. I welded a versatile version of the PC mount so to mount it to various sized trailers but what a pain, I envy the parkit setup but just haven't put any time towards it
beerrun
Pictures please
Mikes56
Ok here’s the pictures, they should be self explanatory.
Mikes56
The bottom post part from the Parkit ball mount is too small to fit snugly into the Powetcaster post part, so I found some aluminum tubing at Industrial Metal Supply in Burbank and made the aluminum bushing. In one of the pictures you can see the relief cut I made with a hacksaw. The Parkit mount fits perfectly into the Powercaster now and it has an aluminum bushing instead of steel on steel. It’s still steel on steel in the bottom, but it turns so slowly that it won’t wear out. I put a little grease in the bottom of the Powercaster post mount.
I have plenty of the aluminum bushing material left over, if a few guys need some. You’ll only need about 3” of it.
I’ll be in Havasu for Desert Storm.
Mikes56
You have to buy the Parkit ball mount because it has a spot weld on the ball to stop it from turning when you tighten the collar up to the trailer reciever. It’s a nice piece of engineering and work from Parkit. I think it was $180ish
A different size ball will thread into their ball mount if needed. It also needs the spot weld to stop it from turning in the trailer receiver.
Oh ok your link doesn't show power dollys
I didn't attach a link. But I have seen his movers posted here over the years. They are a similar deal to a power caster. I tagged him. So hopefully he can chime in and answer any questions and ad a link of where to buy.
Waterjunky
RDP Inmate #94
if your in suburbia, they are the ticket. If you have a little more room, an old forklift is the reigning and undisputed champion. A forklift sounds odd but you will be shocked how much you use it. I use mine all the time..
CoolCruzin
I’m planning on a boat show special coming up this month.
Should be $100 off .
Will move 15k trailers 1200lbs of tougue wt We use three wheels which is important .
Plug it in and forget about a battery .
Want a custom color we can do it .
They have brutal power. Traction controlled by tire pressure.
Love mine.
