SKIDMARC
- Sep 30, 2011
- 3,466
- 3,871
You can get a rebuild kit. About 10 parts. Cheaper than buying new one and then if its still shitty, toss itSorry. Should have clarified. Looking for a battery operated one or a plug in. I have this one but it doesn’t work that well. I have had my lines tested for leaks as my pool guy thought I might have a leak and wasn’t getting enough pressure. No leaks. View attachment 1397776
It hasn’t worked right since I got it. It’s been sitting for a couple years now.You can get a rebuild kit. About 10 parts. Cheaper than buying new one and then if its still shitty, toss it
We have a dolphin. Night and day better than ‘the pool cleaner’ for our pool.
2 or 4 wheel for a Havasu pool?The pool cleaner
I had this one and it was junk. I now have the pool cleanerAfter having Haywards that I would have to rebuild every year, I bought this one two years ago and hasn’t missed a beat. I did have to replace two of the hoses this year, but the vacuum has been great.
I have the same one. It will climb all the way to the coping and scrub the tiles. So far I am happy with it.I have this guy a Polaris Maxx. Works great. Won't do stairs but it will crawl itself up out of the pool if I turn the pump up to high. It has brushes that scrub the walls. I'm happy. View attachment 1397909
Wish I hadn't switched to chlorine tabs during COVID when I couldn't find liquid chlorine though. Now my cya levels are through the roof and I have to drain a bunch of water.
We use 2 wheel, they work with split suction skimmer and cleaner as low as 2000rpm. Minimal parts. Pebble pools they last 5 years + before needing anything.2 or 4 wheel for a Havasu pool?
On pebble the only thing they usually need is tires.We use 2 wheel, they work with split suction skimmer and cleaner as low as 2000rpm. Minimal parts. Pebble pools they last 5 years + before needing anything.
Went through this last year and researched. Definitely a winner and cleans very well.X2 on Pool Cleaner. Efficient and simple. Not much to go wrong or repair
This.^^^^^^^;
I have both, for me the four stays bellow the water line so doesn't suck air and attract cattle dogs who pull it out or remove the tires.2 or 4 wheel for a Havasu pool?
