Pontoon Fiasco
500bbc
My buddy has his 'Toon at Katherines Landing.
Had new pontoons installed aluminum instead of the steel originals.
Boat sits 18" higher becuase of the weight change, prop barely touches the water.
Who's got the simple solution if there is one? :p
HTTP404
New But Seasoned Inmate #2002
Sandbags. Or they can take on some ballast.
Pics or it didn't happen.
I'll work on it, he's lit right now.
He told them to account for the weight difference, they knew better.😜
So....
Just the tubes were replaced, and everything else is the same??
What was the reason for this??
Mine is 28ft.
You can clearly see that the engine is attached to the tube.
If they replaced the tube, why wouldn't the engine be in the correct location???
Is this a delayed April fools joke or something?
wzuber
Typically there is only a center pod on those to house the eng./drive pkg on outdrive type installations, not a full hull.
What a fun situation. The owner really had no idea there'd be a weight difference? The shop doing the swap either? I'd be real concerned about the quality of the shops work if that's truly the case....
wzuber
They could just Fab up an extension for the pod assembly and lower it too. It's just more $$$. Could probably use the extra space for something too?
Inertia...think crusing along then lift, or turn or accelerate
As you can see in the pic you posted...
The logs are welded together, every four feet or so.
You COULD actually fill the center section completely, in each log, and not have to deal with that issue.
Then sell it ASAP! 😜
HNL2LHC
Or gummies...
No way it was RDP gummies, If it was it would be high AF.
As for the fix attach a universal weigh bar. You can increase the weight as needed or remove is you have samoa up front. 👍
Rayson1971
Swap out to twin outboards and mount them on the sponsons at desired height.
500bbc
Owner did, he told the shop before install.
Were the previous toons of the same design? The displacement would make a big difference, and that could change by the bottom.
Also, steel isn't just heavier, steel with a bunch of water :oops:
Crap, those new logs had to be big money too!
Cooter01
Another option is to beat in the bottom of the toons so they are not as round and big, beats filling them up with water.
JDKRXW
Original pontoons are steel ??
Was this purchased from navy salvage ? 😁
oldman
Seems like a huge awe shit, someone should have had some specs. on weight difference and buoyancy.
Adding weight seems like less than an ideal option, but if it's low and equally spread to match the original weight maybe its the right choice.
Sitting higher and having the new toons lighter than the old ones does this create a lack of ballast issue? causing this thing to be top heavy and unstable? It might be a stupid question but not really knowing what it looks like It's just a thought.
