PL 5200 , adhesive from hell
jetboatperformance
Almost all jet application use Silicone adhesive , but occasionally we encounter one that used PL5200 which if you dont know is practically like tire rubber when cured I have a jet to remove that has been sealed that way (PL5200) anyone have a magic bullet for this hatefull shit ?
GETBOATS
Han an outboard bracket installed with that stuff, engine on with no bolts attached to the transom.....would not move
There is a product that dissolves 3m5200, usied it in the above application, bracket came off easily after using it. I'll look for it
GETBOATS
C-Ya
Int’l Maritime Captain
That stuff is a real pain in the ass………
Might I suggest foul language and throwing tools. It won’t fix the problem, but it really goes a long way psychologically.…….
Only kick the dog as a last resort. The dog will probably be already hiding at this point. So you might need to hunt it down….. Lol
I read a lot of 5200 threads on other forums. If there was a secret procedure……. I would post it. The above answer is based on previous reads. lol
Good luck Jet, I wish you luck!
sonicss31
Multitool with the flat blade/scraper attachment. Make sure you keep it super sharp.
If it’s a bolt bedded in that stuff use a car battery for heat.
RadMan
Throbbing Member
I used diamond coated wire purchased off Amazon to cut off a jet pump transom adapter that was installed with that shit. Made a clean cut, no damage to paint around the adapter.
Very time consuming, made handles from 1/2 copper pipe to allow me to pull it back and forth, no paint damage which was my goal.
Remove the bolts first😁
