DarkHorseRacing
- Jun 14, 2014
- 6,628
- 13,142
So you can’t run a blow off valve or wastegate of sorts to get up to max boost early and then just bleed off the excess to keep the boost constant the rest of the rpm band?It will increase the total amount of boost at max RPM. Boost rises in conjunction with RPM with Centrifugal blowers.
You have to set them to make the peak boost you want at max operating RPM, and then you only get what you can down low as it spins up.
