Octane Booster?
88Checkmate
I have a Mercury Racing 500 EFI engine in my boat.
I can only get 88 octane - no ethanol at the gas station close to the lake where I use the boat, should I use an octane booster ?
pwerwagn
Inmate #4800
I can’t answer whether or not you need it, but if the inmates say yes, look at the BND Aces octane booster.
farmo83
Should be fine as merc calls for 87.
HP500EFI Specifications
Propshaft Horsepower: 470/350
Displacement (Liter/CID): 8.2/502
Cylinders: V-8
Bore (in/mm): 4.47/113
Stroke (in/mm): 4.00/102
Compression Ratio: 8.75:1
Fuel Requirements: 87 Posted Octane (R+M)/2
Full Throttle RPM Range: 4800-5200
Ignition Type: Digital
Alternator (amps/watts): 60/847
Length (in/mm): 34.3125/872
Width (in/mm): 33.75/857
Height (in/mm): 22.0625/560
Weight (lbs/kg): 1305/592
Warranty: 1-year limited, 3-year limited corrosion
