Obsolete truck part question
Sawtooth
Thanks for everything Dad
So I have a ‘92 OBS Chevy 2500 work truck that I can’t go another summer in without A/C. The problem is the HVAC control is not available any longer. I have purchased 3 used units from different sellers on eBay and they only last between 6-12 months and then stop working.
Question is with all the great mechanics here does anyone know of someone that actually rebuilds these. The ones from eBay just say “tested”, not rebuilt.
I have found guys that rebuild the dash/gauge cluster and install new stepper motors etc. but no one that rebuilds these controls. HELP I’m already starting to melt 🥵. Thanks
joecfd1
I’m thinking you need to add a mini split and generator to your truck… problem solved! 🤣🤣🤣
wzuber
Another OPQ......does anyone know of an aftermarket company that makes egr coolers for the gen1 lb7 duramax trucks?
I'm told they're no longer available from the mfg. Tia
That's a Cali emissions thing. I didn't know that until I moved here. The LB7 Fed trucks didn't have them. That's kind of the issue though, limited market. I found an NOS one on ebay a couple years ago for a customer. It's kind of a bastard.
Sawtooth
Hey mobster thanks for the link, but these are the same as all the ones on eBay…..
“Extensively tested” not rebuilt, they are just pulling them out of wrecking yards. Another giveaway is there is no core charge because they don’t rebuild them.
There is a 1 star review for the item at autozone in the link you posted, is says “Did not work had to return” 🤣.
Sawtooth
You know me to well, don’t think I haven’t thought about that 🤣🤣!!
I saw that.
It's also just ONE review, and I'm going to guess they made it right?
It's a Dorman part. It's probably sold everywhere, and I'm fairly sure it's fully warrantied?
Sleek-Jet
Did a little googling on Rivermobster's suggestion, these appear to be new aftermarket parts...
Sharky
Is everything else working and just the AC having problems?
Read this TSB. 92-201-1B
Repaired several vehicles that had AC problems with this complaint
This is a rebuilt unit (or claims to be). I would reach out the seller/rebuilder and see if you can send in one of your failed unit to have them figure out what went wrong. Something is killing them, and to determine what is killing them, we have to determine what is failing and on what circuit
bonesfab
Vintage air makes an upgraded a/c kit for those trucks. Not just a switch panel though.
Sawtooth
When the dash control units work everything works great, A/C is cold, heat is hot, defrost works/blend door works to move air from dash to floor etc. Thanks.
Andy B.
Be thankful you don't have 2000-06 Dodge 2500 my blend doors broke( plastic junk) had to replace! Had to take apart dash the whole nine yards. Replaced everything and found some aluminum blend doors so they should last the life of truck.
Sharky
Sounds like the problem is intermittent. When the problem occurs, what does the control head do?
Go blank? No display?
Or, is the display still lit but nothing happens when pushing the buttons?
Sawtooth
So each one has died a little differently. One started by not being able to control the blend from dash to floor and In between. Another one all the lights went out so I could not tell where it was set. And the third one worked the longest, about a year, and then one day when I started the truck all the indicators that show temp, where it it’s blowing, what mode it’s in etc. just started flashing then after one minute it would go black. Then if I pressed any control it would all flash again for another minute but nothing would work.
At this point I’m seriously thinking about just making an aluminum panel to fit in the space with a few basic toggle switches.
Definitely frustrating.
What's the warranty on the Dorman part?
Sharky
I would be tempted to take one apart and look at the circuit board.
This is the era (GM-Delco) of really lousy solder and broken solder connections. Where the pins on the electronic components come through the board and the solder is on the back side. We replaced thousands of ECM's and modules for failing the "tap" test.
You got an intermittent complaint on a GM. Powertrain, radio, HVAC, etc. And normal diagnostics found nothing. Powers & grounds good. Connector/terminal fitment good, no DTC's. . . . . . Take a wooden dowel (or hammer handle) and "tap" or smack the module. Then the problem would happen.
We had stacks of ECM's in the warranty return cage.
Pop it open and see if you notice any bad solder joints. Re-flow the bad connections.
Or, go with a reliable auto parts store that has a decent warranty and keep replacing them.
