obnoxious001
Engine building character
- Dec 28, 2007
- 6,619
- 4,139
It would be interesting to see where the break/crack initiated. Unless its an optical illusion caused by the shot peening, it looks as if the radius was increased in that lower pocket area in the newer version. Obviously torque played a role and anyone running these older style may want to look into doing some dye penetrant testing to see if theirs are cracked before reinstalling them during a rebuild.
Yes, beyond the shot peen, there are some design changes. Speaking with Jesel, they suggest that if the rocker has been damaged by over tightening the adjuster nut, the adjuster will not turn easily. Paul decided it would be prudent to change them all out even though it appeared that the remaining rockers were ok by the Jesel method.
What kind of spring pressures are you running?
Pretty mild, about 600 open. Jesel and others I talked to said that should not be what's hurting the rockers.
