New wheels & tires for 240 Hallett?
JAA_CBA
Doing resto mod on a 240 Hallett by GT Marine. Not going crazy, but should be very clean and most "dated" stuff upgraded.
Refreshed the trailer, looking for suggestions on wheels and tires.
Design and size?
UltraLucky
Very nice 240. Are you going wider on the fenders? looks like you have the originals. On my 210 changed the 14” rims to 15” and kept the same tire diameter also went to a 9” fender and lowered the fenders it a bit.
DarkHorseRacing
Based on research I did for a trailer build, 225/75R15 seemed to be a very common size with a lot of tire choices.
I’m a big fan of being able to find a tire should I need one and not running some non-standard size that no one stocks.
What the wheel looks like is totally up to you but I would avoid anything chrome. Polish or powder coated only.
As for tires, I’ve had good luck with Carlisle Trail Rite HD, but I’d try to go with Goodyear Endurance first.
You could also consider going to a quality car / light truck tire as well. As mentioned above, find something you like in a common size that's readily available. Wider fenders would definitely change the overall look of the trailer. 👍
River Dirt 2
Brummett 21
On my sons 240 we did some trailer upgrades, originally tires were 205/75/15
First 2 pictures are where we started from.
Made new taller guide posts, wood and carpet to get up to rub rail height
Converted from drum to disc brakes
Converted brakes from surge to electric over hydraulic
New wider stainless fenders with new skirts and carpeting
New 225/75/15 Goodyear Marathons on original Raceline wheels
New winch
New jack
Here a simple tire comparison for 15, 17, and 18
evantwheeler
Polished Alcoas or Weld Super Singles is my vote
JAA_CBA
Nice work on your trailer. I'll probably leave the fenders the way they are, I know wider looks better. Do you think the tires you put on would fit with the thinner fenders? You didn't go wider with the rims, but looking at your pictures, your new tire size might be out past the edge of the thinner fender?
View attachment 1385305 View attachment 1385306 View attachment 1385307 View attachment 1385308 View attachment 1385309 View attachment 1385310 View attachment 1385311 View attachment 1385312 View attachment 1385313 View attachment 1385314 View attachment 1385317 View attachment 1385316 View attachment 1385314
New winch
New jack
River Dirt 2
Brummett 21
Thank you.
Don’t think the bigger tires would have fit with the existing set up. Now some of that may be due to the offset of the wheels. I did not like the look of the smaller tires as they stuck out too far with the stock fenders, bigger tires would be worse.
