DaveC
Car-boat motors
- Sep 25, 2007
- 11,177
- 6,351
How’d the boat run the other day with eliminator ?
We just built a very similar motor for our Howard cat, but we're running 10.5:1 compression and we made 725hp on the dyno with no accessories and dry exhaust. You're probably making low 600's with a good tune.
Why would you think this motor is making 100 less hp with only 1 point less compression?
That point should only be 25-50 hp I would think.
Compression 9.5:1.
Cam: 256/264 @ .50 duration, 632 lift, 114 LS
Mainly because our dyno numbers were with no drag on the motor and dry exhaust. I think trimmed out in the boat or motor will be closer to 675
copy you were comparing dyno numbers to in the boat loaded numbers.
I bet daves engine is in the 675++ range. I know it has good parts and great heads with a kick ass EFI set up.
You probably loose more than that through the drive when everything is installed. (I would figure loss at 15-20% but I honestly have no idea on a boat compared to a car)
Just to be clear I am not sure of a few things about my setup. I am trying to extrapolate a few things from what we know by comparing mine to other 26 Daytonas mostly with HP 525s.
My motor is supposed to have 700-725 HP. I don’t know much it has exactly because we did not dyno it.
I don’t think it has 700-725 HP. But I don’t know how much I got exactly to say for sure so I am guessing.
My un-educated guess comes from my RPM being 200 RPM more than a like Daytona with a HP 525. Beyond that who knows.
I think there might be some gains by tuning but that is based upon a hunch but not any data.
I wish we would have put it on a dyno to know for sure
My seat of the pants dyno tells me somethings up. I don’t get any acceleration beyond about 2/3’rd throttle. That sees odd.
I don’t think it has 700-725 HP. But I don’t know how much I got exactly so I am guessing.
Here were the results of the leak down test done by Teague last summer. I just noticed it. All cylinders leaking on a brand new engine.
At this point the engine had only 7 hours and should be broken in by now.
I have been in a 26 Daytona with a 525 and the boat didn't hit 80 with 4 people and fuel and sucked getting on plane.
I think a 27 speedster with the same 525 would be slower....lets say 75-80 mph propped to the moon with a light load.
If you are at 85 -90 mph I think you are close to 650-700 hp personally.
I think you have 2 issues. 1 I think the boat needs a good tune and a goo prop to get the slip down. 2 Honestly I think you were expecting more mph and more oomph out of what you have. A 540 needs a decent amount of cam and rpm to make 700+ hp and I think it's going to be very hard to get that program past 5500 rpms.
So while I think you probably do have close to 700hp out of the boat on a dyno you are probably closer to 600-625 installed and under load at the rpm level you are hitting.
I think you were trying to achieve Merc 600 performance levels in a less expensive NA build. Taking the fact that you got hosed on the whole program out of it I just don't think that engine will do 600 SC things when you factor in that merc always makes 600hp regardless of elevation and heat and has the TQ to move a big heavy boat.
Get it tuned and enjoy it at 85-90 or now that it is a teague 540 with a clean bill of health and relatively low Compressing go the whipple route. It's a beautiful boat it's just missing that last 5-10 mph you are after.
Boating sucks....lol My buddy has a beautiful brand new 200K Fundeck with a 565 that ran 78 mph with zero gas and 3 of us on board and a long runway. I drove that same boat with 10 people on board and it was terrible and a 64 mph barge...haha
Dave I'm near certain I have a labbed 28, and a worked over 28 to a 27 that I can ship down. I might even have a truck headed that way that could probably drop them off along the way.
Under 20% is fairly normal on a healthy engine...you can't seal up the rings when the engine isn't running. Either a valve was open on #1 and #2 or something was hurt
I think we are close in thinking here. I think there is a few more MPH in it under the right conditions. I am looking at optimal conditions not summer time with 6-7 people on board in the heat with enough beer for RD on board. LOL
I am looking at the RPM also vs. the 525 and we are close. Not just the MPH.
We have tried so many props I lost count. I agree with your thinking on the maximum RPM at 5500. I am going to pick up a labbed 28 to spin it a bit higher.
The open bow 26/27 go slower. So hopefully we can get my slip down a bit.
That being said I agree on the tune. There is something missing in the upper band as the stick feels weird. I may be wrong but its worth looking into.
we are actually going to look at the tune myself here soon if I ever get the boat back. It is a holley EFI and we have the software.
Man that sucks. If Teague does the motor would they tear it all the way down and start completely over so that it’s a true “Teague” motor?
A new twin OB boat might be an option. Can't argue how bad ass they are in the Speedster.
I will probably bring the boat to LA at the end of the year with a for sale sign on everything and see what sells first.
If the boat actually sells for decent money then I might build a new one. Either with a Teague motor or twin OB's.
Keep in mind a new boat will cost $20,000 in sales tax.
Just my opinion: either sell that motor & drive & buy the correct motor/drive OR sell entire boat & buy another boat. The OB boats, even with 400s, don't accelerate very well unless very light. ALL outboard boats struggle when you add more weight. You are welcome to ride in my boat anytime.
There are plenty of very good used boats for sale that are proven & you can test drive to see if they do what you want. If I were you I'd be going the used route WITH WARRANTY. Good luck
I would sell the motor you have now, there’s probably some good value in it now that it’s running right. And buy a Teague 825. It’s actually a very mild mannered motor, easy to maintain, very turn key. We know that motor in that boat will run 120. Eliminator and Teague already have the formula on it. I think you’ll find if you try to Whipple your motor you’re gonna end up changing too much stuff and throw away all your old stuffYup. Thats the problem.
Most of the stuff is good but it would need new pistons/rings anyway so I know it will get an entire top shelf rotating assembly ($$$) by the time it is all said and done.
I just have to eat the costs
I just went and read thru all 8 pages of this thread. What a nightmare, I feel for ya. Good news is your boat is beautiful, love the gel and interior, and not just because I’m a big Dodgers fan!This is the preferred route actually.
I need to have a discussion with them about rebuilding versus buying new but that is probably the jist of it. Whatever they recommend is what we will do.
It might just come down to selling the old one and starting over.
This one they finished up early this year hit 120. Not sure if that was light load and propped to the moon or not. The potential is there, but agreed, 115 is probably a realistic everyday speed.This is spot on advice. I'm not sure about 120 but at least 115.
https://www.riverdavesplace.com/forums/threads/2018-tcm-825-27’-speedster.183214/
Question X2?What’s the price if you were to put it up today? Asking for a friend![]()
Asking $175,000.
Its for sale now if anyone is interested.
Wow, what a roller coaster of a thread. I can't believe i missed this over the last couple years.
I hope everything works out for you, the boat itself is beautiful. You have a lot of patience, and restraint.
