locogringo
Yo Mama
- Dec 27, 2007
- 733
- 398
Try turning the pump on, just until it over flows the bottom filter half, turn pump off. Push down on the top of the filter. The suction should help get in back into place.
And yes, the goal to-ring is still perfectly round
Where are you located?
On the Purex filters this trick works. Haywards it is all about the lube.
See, this is the gap I'm left with...
Guess I'm gonna go and buy some lube
Yes, true. I did like that stuff better. It's been over 10 years since I had my pool business. My memory sucks!
The size of the gap that I see in your picture would lead me to believe your problem is inside where your filters are. I have a Hayward pro grid filter system and I'm guessing our filters are somewhat similar. When installing the filter grids did you 1st lubricate the outlet tube and o-ring and also the inside of the tube connector of the manifold. If those two pieces don't go together properly the the filters won't seat down to the lower filter body. That may be the reason for the big gap that you see between the upper filter body and the lower filter body...
Go get a new tank O ring, get the silicone lube Lumpy mentioned an clean both surfaces the o ring touches, check for what Nowski said.
Next time, cut that pile of shit filter out, call me and I will send you the right filter.
And for christ sakes cut the hedge back.
