Need a little 12v help.....
Waterjunky
RDP Inmate #94
Hello all,
I am adding a circuit to my RV and need a little help figuring out the best way to wire it.
I am adding a large secondary fuel tank and the builder sets them up with a small transfer pump to move fuel to the primary tank. As a smart decision, a timer is used so not to over fill the primary. What's used is a Spring wound standard wall timer. Think like a bathroom fan. Cheesy but technically functional.
What I want: A digital timer that I can bury somewhere controlled by a 3 way rocker switch (momentary) that I can mount in the dash that matches the rest of the switches. Push it up and it starts the timer and it runs until it stops. Push it down and it stops no matter where in the cycle it is.
Sounds simple but what the heck to I use for a timer? Other suggestions?
I'm struggling to cut one of these into the dash:
I really want something like this visible instead. I just need to figure out the timer / relay part.
I also really like the idea of being able to turn off the timer if something goes wrong.
Thoughts?
Ideas?
Better ways to do this?
Maybe something like this? There used to be other ways, but they make a packaged unit now like this. Use a momentary rocker to trigger the relay, and the relay to trigger pump. Depending on the transfer pump, may have to use it to activate a bigger relay for the current draw.
paradise
Spooner
You should be able to find a delay off relay with a cancel function. The relay will get the larger gauge wire for current draw with continuous power, and you’ll just run a signal wire to your momentary switch on the dash
A timer is NOT going to keep the secondary tank, from over filling the primary tank.
Does the primary tank even have a level sensor, or gauge?
I ask because mine doesn't. 🤷‍♂️
Waterjunky
RDP Inmate #94
Nope, a simple timer would not. However that is why it doesn't get tripped until there is adequate room. This is also exactly why I would want some way to shut it down. If is certain youth's fingers suddenly help out, I can unravel the situation. Because all you with kids know- that never happens......:rolleyes:
Yes the primary tank has a gauge. It technically has saddle tanks like a OTR truck but they are the smallest tanks available and are married together. The auxiliary would just feed them. Set the timer to transfer something safe and reasonable like about 30 gallons.
If you wanted to get all tricky and shit...
You could probably have someone program a Rasberry Pi for you.
It would have to read the gauge signal wire, and then turn off the pump relay at a specified resistance.
Above my pay grade. But maybe someone on here could do this?
BamBam
Use a timed relay. they are available on Amazon. I have used delay timed relays on projects but they make some that run for different lots of time and are adjustable within that range. you would simply flip the switch to on which will close the circuit in the relay and it will run until the timer in the relay opens the circuit at the time you set. If you want it to open before the timer is up you flip the switch off and take away the power.
JUSTWANNARACE
I will not let them take me🤣🤣
Sounds like alot of extra stuff that could go wrong or fail. Why not just run a line from the bottom of one tank to the bottom of the other?
gottaminute?
Hello all,
Thoughts?
Ideas?
we used something like this for "underhood" work lights in some equipment so the batteries wouldnt go dead from the last guy who worked on it leaving it on.
ours were built with 30 minutes off delay. if you switch it off, it shuts off right then.
JUSTWANNARACE
Worked for semi trucks for over 50 years. A lot of RV's do that with fresh water tanks too.
That's how I used to set up the auxiliary fuel tanks in all the side x side builds I did. Did in my toy hauler, never a problem. No need for an extra fuel neck either🤷🏻‍♂️ easy, simple, no electronics or pumps to fail or forget about!
Waterjunky
RDP Inmate #94
My issue is the tanks are not level. The new auxiliary tank will be better than a foot higher than the primary. Its also 25 feet away.
$hot
To say what? :)
Waterjunky
RDP Inmate #94
what about one of these
I was actually getting fairly excited about this one. It also functions as a gauge for the auxiliary tank, solving additional issues I'm working out. Just got off the phone with them and they used to sell them outright but now only with their tanks and only on Ford, Chevy and Dodge.
