Waterjunky
RDP Inmate #94
- Sep 24, 2007
- 5,010
- 4,456
Hello all,
I am adding a circuit to my RV and need a little help figuring out the best way to wire it.
I am adding a large secondary fuel tank and the builder sets them up with a small transfer pump to move fuel to the primary tank. As a smart decision, a timer is used so not to over fill the primary. What's used is a Spring wound standard wall timer. Think like a bathroom fan. Cheesy but technically functional.
What I want: A digital timer that I can bury somewhere controlled by a 3 way rocker switch (momentary) that I can mount in the dash that matches the rest of the switches. Push it up and it starts the timer and it runs until it stops. Push it down and it stops no matter where in the cycle it is.
Sounds simple but what the heck to I use for a timer? Other suggestions?
I'm struggling to cut one of these into the dash:
I really want something like this visible instead. I just need to figure out the timer / relay part.
I also really like the idea of being able to turn off the timer if something goes wrong.
Thoughts?
Ideas?
Better ways to do this?
Thoughts?
Ideas?
