TPC
Wrenching Dad
- Sep 20, 2007
- 31,925
- 26,114
TPC, is that tubular or beam? If tubular you could go inside? Other than drilling holes and attaching with cushion clamps the only option I see are zip ties. If they are breaking every trip try some from an electrical or air conditioning supply house or McMaster Carr.
Hollow tubes.
Inquiry with Pacific and I just get the "You take good care of that trailer son,, We build the best trailers in the World".
TPC,
Here's my solution...
Stainless Steel Square U-Bolt around the Axle w/ backing plate (not pictured in diagram).
Aluminum or Stainless Steel Loop (aka Cushion) Clamps (black), to hold the break-lines (orange)
Stainless Steel Nylock or Flange Nut to secure.
View attachment 473062 View attachment 473061
Our Pacific Salt Water trailer came with wire ties holding the brake lines. They lasted the drive home from Pacific Trailers and are detonating.. I'd like to not drill the frame to attach the line permanently and would like to use something better than wire ties.
Any takes for a proper fix?
Cushion clamps, ss self tappers, seal the threads.
Hollow tubes.
SS Hose clamps. The flat band kind would even look good
I used to build trailers for Pacific... we welded washers on end to the axle. The assembly guys popped a rubber grommet in fished the brake lines trough. Wiring was done the same way.
Its been a long time since I have been to their shop, but I don't recall ever seeing anything leave like that.
I'd be taking the Trailer back so they can fix it the correct way like mentioned above ^^^^^. Zip tie's will only come off after time.
Duct tape?
They don't want to talk about it, it's feudal.
I've invited the owner to come in a discuss it in RDP,, still a no show.
I ain't out to tee him up but I will post my experiences.
