Orange Juice
- Oct 2, 2017
- 5,637
- 6,721
This will work. I’m using one of them in drywall holding 18 lbs, for 20 years. I think 6 would hold a 65” “new” TV. They seem pretty light.The tv weights up to 75 - 100 lbs
4 or 6 spring loaded toggle bolts will hold that no problem! I would go 1/4 inch and get a good hex head bolt! Make sure you go thru the foam ! You can set the anchor loosely and spray in some Big Gap Foam filler and quickly take all the slop out of the toggle let it sit. The foam will expand and bit onto the toggle bolt & give you a much bigger surface area to resist pulling into the foam. If you tighten it up too much you’ll just crush the foam inside, back behind the stucco.
View attachment 1181076 View attachment 1181077
