Tooms22
On Vacation
- Nov 25, 2015
- 2,253
- 5,591
I need to mount a 65" TV on stucco this weekend.
I've done a 32" with the toggle/zip tie-ish type anchors but this TV is larger.
On the inside of the of the stucco wall (inside the house), about half is drywall and the other half is a corner fireplace tiled wall. No chance of verifying the location of the stud behind there.
So measuring in from a window frame, I could probably find and confirm one stud inside through drywall and measure the same on the outside stucco wall to hit that stud.
What about the next stud over? Just measure on the stucco side where the next stud should be, drill, and look for wood shavings?
Could I just use 4 toggle anchors through stucco with that big of a TV? or two bolts into studs and two toggle anchors?
