DaveH
- Sep 9, 2008
- 2,856
- 4,195
or the injectors are partially clogged from our crappy pump gas. just because it blinks doesn't mean the fuel is getting through.I KNOW you know better than this!!!
A fuel injector has voltage at all times.
The computer Normally supplies the Ground circuit to the injector. It you hook a test light to Anything computer related, you'll likely fry the computer.
The correct way to verify the ECU is trying to fire the injector, is to use what's called a Noid Light. You plug it into the injector connector, and see if it flashes, or not.
OTC (3054E) Noid Lite/IAC Test Kit https://a.co/d/bsEivzX
