Looking Glass
1 = Well = Known = Member
- Jan 6, 2020
- 9,707
- 16,883
EVERY Time I have attempted to save 50 Cents, it has cost me $50.00. Do it Right, Once!!yes…..the isntall plays a far bigger part of the longevity of the unit than the name silkscrrened on the cover.
keep in mind these things should run for 10-15 years trouble free. most DIY are proud to see 3-5 years.
if you know someone or if you are capable of performing the install and start up correctly you can save yourself a considerable amount of money. truth is most DIY systems are far from properly installed and most if not all contractors won’t touch them. the install is more than just mounting some things to the wall and connecting pipes. In ca permits and inspections are required as well which adds to the cost to have it done correctly.
the most common install issues are improper flares, not correctly torqued fittings, contaminants in refrigerant, incorrect drains, and don’t even get me started on refrigerant lines and electrical we see.
most people are proud of the fact they hooked it up and it kind of blows cold/hot air. when we see their work of art we politely step away and decline any type of service as we don’t want to inherit the longe temp problems and warranty issues.
