707dog
- Apr 2, 2010
- 3,643
- 4,389
hell i thought you were describing ol 2FFWhite haired guy mid-60ish, wife about 10-15 years younger, and 2 springer spaniels?
So in summary:
It’s a great motor to start a build.
Once you upgrade all of the weak links.
the 540 motor?2FF- what do you think about the hp500 "bulldog"?......holygrail?
the 540 motor?
I dropped the prop off on fri on the way to the lake...hope it works for you...I have seen Gill manifolds make huge improvements over stock manifolds. Much better then Imco or Eddie Marine. Don’t forget about the valve spring height issue with Merc. 500 engines so there is clearance for those short valve covers they use.
pretty sure, though didn't see it with my own ly'n eye's... that merc has a pretty elaborate dyno and they read AFR to each cylinder... that's how they knew to do staggered jets on the carb...what I do,,and what I did fri at the dock... I start the motor,,,and let it warm up running at the dock....it's easy with the gil exhaust... if you touch down by bottom of the manifold, each cylinder will start getting heat,,.. that lets you know each cylinder is firing... after letting it run, I still had 3 ports cool to the touch...that told me I had 3 dead holes so I just loaded up and came home...I do the same test on header motors, but only I do it with a wet rag...tube headers will burn the shit out you... it's kinda like the shop towel fan clutch test... some of you might wanna watch it done first....lol... when I used to race alcohol motors, we would run the motor till you felt heat in the heads with your hands before making a pass, in the pits the same process , then run the valves..and at the same time I could do a exhaust port test to see that all holes were firingMonitoring to each cylinder is less important and not the same as delivery to each cylinder. EFI with port injection and decent injectors will deliver equal fuel to each cylinder at a given load. A single carburetor can not.
I've had 502's leak down over 75% and on the same motor bring it up to less than 10% just running marvel mystery oil ...and I sudjest to every one to run marvel in their oil, and lucas in the fuel...marvel WILL re seat rings...although all my plugs were fuel fouled, I was happy to see them all black,, one white would have ment pull the heads today..I'd like to get through this season,though it's time for a tear down, I wanna go back with aluminum heads, and of corse valve train up grades...I did the head swap to aluminum on my last hp 500 and was able to go up two prop pitch sizes...a well known problem with that engine is the rings going away.
leak yours down.
seen them go away after just 250hours.
I don't know if its because of the ring package merc uses, or possibly the hone finish on the cylinder wall, or the excessive fuel merc tunes throw at the engine that shortens ring life.
and yeah...there is a world of difference between the modern port injected 8 channel systems vs the one size fits all approach merc runs.
Hope all is well up your way, hows the legs doing..? like I said in the first post,,there'll be a lot of people that disagree... and jaws dropping, some people will argue with the sign post and take the wrong road home...I think they put the valve covers on top of the motors to make it easy to take them off, while most think it's so they can put pretty ones on easy ....lol.. good to hear from you... when's havasu trip, and as you know, you and the family are welcome at my havasu or vegas home anytime..keep the input coming some people will be like what the fok is the geezer rambling on about... then guys like myself who have spent the $$ building a motor mocked after the blue ball 500 motor pay attention and enjoy the reads. although i went with the HP 525 efi cam for my build the same maintenance stands and have already left that money in my engine builders tool box to take care of the heads when its time still have 150 hrs to go
It means the bores are joined together at the sides with no water in between where they are touching.What is a siamese bore ? I've heard the term but have no idea what it means.
Thanks Steve i will give it a whirl. I actually ran a Mirage plus on my boat this weekend and boy did the boat like it! I finally got the engine to spin 5K and the speed was way up there and the idle speed wondering at the wheel i use to have is almost non existent now.I dropped the prop off on fri on the way to the lake...hope it works for you...
Cliff notes of summary -
Great motor once you replace everything.
Which describes every build on every motor ever done.
Disassemble, throw away damn near everything but the crank, bare block and cylinder heads, valve covers, maybe the rods and oil pan are reused.
....and maybe a handful of bolts.
Start over.
Brian
Seems like factory motors have come a long way, stock components are pretty stout these days. Hell - the head gasket of choice for 25+ lbs of boost on a LS Motor, is a factory head gasket!
Typical LS3 N/A build
-swap camshaft and springs , retain stock lifters
- Tune it
- Beat on it for years / 7000rpm
Right.
Suit yourself.
Years. Noted.
Well until 10s, or 100's, of thousands of LS motors are in hotrodded boats and cars for 50 years, I guess the jury will still be still out.
Brian
“Until 10’s of thousands of LS motors are hotrodded” - lol
I thick that milestone was eclipsed In 1997? This is a 21 year old platform at this point . Your more likely to find a LS in a fox body mustang that you are a 5.0 anymore, and THATS saying something
Youre.
It is??? Considering the 5.0 was always a POS, since prolly 1964, I don't think it is any benchmark to rest an accomplishment on. Piss poor rod ratio and a short deck to boot. Aint worth fuck for nothin.
Brian
So I've got one of these motors right at 300 hours. 1997 gen 6 with the seals still on it. I've got three seasons on it with nothing but basic maintenance. It runs great and I really don't want to F with it. But it's probably wise to start to thinking about it. that being said, the valve train is kind of noisy in my opinion but I have heard that that is the nature of the boast.
I'm not looking for more power so whats the minimum to get me another few seasons? Obviously the heads need to go to the local machine shop for a valve job and springs. If the rockers look OK are they good to keep running? Lets make a list of required parts to replace assuming the short block stays in the boat. I'm just enough of a wrench to do the work myself with a little help from the RPD knowledge base. When I break down and do this I don't want to spend more than I have to but I want to use good parts that will hold up?
Head gaskets for sure. Which ones are recommended?
Head bolts? Studs? Reuse?
Which springs keep the correct height?
If the valves look good do they need to replaced or just a good valve job?
Rockers?
Push rods?
Lifters for sure. Which ones will quite things down a little bit.
Timing chains don't seem to be a problem.
You're. Yoooor, yore, yoooorreee, please.
Think.
It is??? Considering the "5.0" was always a POS, since prolly 1964, I don't think it is any benchmark to rest an accomplishment on. With it's piss poor rod ratio and a short deck to boot. Aint worth fuck for nothin.
Brian
Right.
Suit yourself.
Years. Noted.
Brian
“Mopar or no-car” is all I’m hearing
Volvo Penta V8s are LS based. I’d/yoood/anyone would have zero problem swapping a cam and valvesprings to get a 500 HP LS in a bote.
I have seen many of the 500 carb and 500 efi engines go well over the 500 hour mark with proper maintence. The rockers arms seem to be the weak link and i cant tell you why because they are a good quality Crane roller rocker arm. But everyone of these engines i see fail these always broken rocker arms. It really depends on do you babby your boat or run the piss out of that will be the deciding factor.So I've got one of these motors right at 300 hours. 1997 gen 6 with the seals still on it. I've got three seasons on it with nothing but basic maintenance. It runs great and I really don't want to F with it. But it's probably wise to start to thinking about it. that being said, the valve train is kind of noisy in my opinion but I have heard that that is the nature of the boast.
Rockers?
Push rods?
Great, now the thread is going off the rails from the OPs request and somehow rd is going to blame me for it. lol.
Volvo/Penta....another benchmark accomplishment in the boating world, but you go swapping your roller(prolly) cam onto your used lifters and run it.
Lets get back to 2FF stroking his love/hate deal with the HP500.
Brian
It is always yoooore fault Brian.
Brian
The 2 biggest problems with the HP 500 were the heads, and the cylinder bores.
Stock heads were 325cc runners, IMO too big for that engine to provide enough port velocity for a proper carb signal, causing incomplete/insufficient fuel vaporization.
The Cylinders were not honed with deck plates by Merc, resulting in bad ring sealing/failure.
Fix those, and they’re solid engines!
If your trippin on re-using roller lifters....wait till u see me sliding in a reground cam! . #itgetsworse
A few cheap inline spark testers will tell you if you are getting fire to the plug, and its not too difficult to see if said plug is firing.
My question is who and why were the plugs installed with an .022 gap ? This makes no sense at all ...
also , what became of the spaghetti steering lines and slop.
Dont get me started...my last 408 had Chinese RPM rods and crank lolChina head studs? Say it isn’t so!
So you are saying it is solid after tearing it completely down, re machining the block and putting all new parts in it .
