FROGMAN524
- Mar 16, 2013
- 6,363
- 12,345
The engine doesn't know it's in a boat.
V-drive. Or jet.
Dry headers.
Done.
Dan'l
V-drive. Or jet.
Dry headers.
Done.
Dan'l
Not really. There are differences running an engine in a boat, primarily block temperature never gets up to automotive running temps without a thermostat setup, and operating RPM's are continuously much higher in a boat, similar to a race engine.This guy gets it![]()
Agreed. Temp control is key to making it work.Not really. There are differences running an engine in a boat, primarily block temperature never gets up to automotive running temps without a thermostat setup, and operating RPM's are continuously much higher in a boat, similar to a race engine.
Isn’t LSA pretty important if running water cooled exhaust?Not really. There are differences running an engine in a boat, primarily block temperature never gets up to automotive running temps without a thermostat setup, and operating RPM's are continuously much higher in a boat, similar to a race engine.
I ran a GM 502/502 crate for years in a jet boat, guessing 6-7 years. Ran the shit out , my final run was just over 30 minutes at 5500 rpm without an issue. Sold the boat the guy ran it for another 3-4 years, no issues.The engine doesn't know it's in a boat.
V-drive. Or jet.
Dry headers.
Done.
Dan'l
The head is basicly an Olds DRCE cyclinder head. I think prostock still uses some of themI’m less interested in the engine as a whole for boats and more interested in the new heads that they designed. As soon as you can buy them bare it would be a lot of fun to play with them. They are essentially a mix between a massive BBC 12 deg setup with stuff they learned from the LS engine. It’s a completely symmetrical port big nasty flow piece but without offset rockers and much more efficient chambers. The intake ports are so high up they can run a separate aluminum valley tray to insulate the intake from oil and coolant. That’s where they stuck the coils on the zz632 (like a viper motor)
Anyways, some other interesting tidbits: they are running hydraulic roller on a 780 lift (1.8 rocker ratio) 270/287 duration big ass cam. Giant 2.450 intake valve but only 1.800 exhaust and 5/16 stems. Might want bigger exhaust valves and 11/32 stems for forced induction but then you get back into more weight and breaking valvetrain parts. Only 70cc chamber size I’m assuming because they have the valves so flat to the piston (standard bbc open chamber is 118 to 124 these days).
As far as the bottom of the motor it’s all high end parts. It would be interesting to see if it would detonate with that 12:1 compression at 6000 rpm steady state with cooler engine water. You would want to check what they clearance the motor at and run oil thermostats. Conversion to a dry sump would be a good idea. I’m thinking the chamber design is allowing higher compression in pump gas or their engine controller is super dialed into knock detection. That can also not work in a boat as it thinks propeller harmonics are knock.
This engine is the biggest advancement in the bbc platform from an oem perspective in decades. I read that they were developing this head in the 90’s and it got shelved. When they brought the project back and started Dyno testing the final combo, they redid the intake port with CFD modeling but the original hand done design was actually better in the real world.
