Internal meat thermometer help
JUSTWANNARACE
I will not let them take me🤣🤣
WTF am I doing wrong? I bought this today thinking it would make it easier. I have never used one I have always gone off time and touch always worked well for me. Thought I'd step up in the world of bbq'n. 3lb tri tip, pellet grill set @ 225. Been in for only 30min. Says it's already 125⁰. I'm confused cause everyone says to pull off around 125⁰ and let rest for medium rare. No way this thing is done. Moved the target temp to 130⁰ now it says estimated time 40min🤷🏻‍♂️
DWC
View attachment 1491648 View attachment 1491649 View attachment 1491651 View attachment 1491652 View attachment 1491653
Is the probe in the center? Try a couple different spots and see what the reading changes to. The probe that came with ours was off by 15 degrees compared to my trusty handheld. That meat would be scorched to get that warm, that fast.
JUSTWANNARACE
Added another probe and it says like 135⁰
Checked in a few different spots.
Back to touch and time I guess
TrollerDave
Tri-tip?
Don’t use a thermometer. Tri tip is a very juicy piece of meat. You can gauge it with how it feels compared to what it’s like between your thumb and forefinger. -Hand relaxed=rare
-Hand closed like a fist but not tight= medium
-Hand fist tight= well done.
JUSTWANNARACE
Tri-tip?
This is how I've always done it
Caydens Cat
all I got was a t-shirt
That big thermometer looks pretty, and likely conducts a lot of heat. Thermometers are usually thin because of that!????
JUSTWANNARACE
Well in a reality, it was pretty damn accurate!! The cut was just really soft and loose. Should have pulled it @ 125⁰ then seared it. I pulled @ 130⁰ then seared. Just a hair more done then I like it to be but not over done by no means. It'll take me some getting used to using a thermometer. So not money wasted for it I guess.
The wife made some red potatoes and a salad. All in all it was great!
dspracing
I’d do the calibration test on your probes and also check your grill temp using your extra probe. It’s possible that your grill is running much hotter than what it thinks
You have to trust the probe. They work
If you want more sear leave the meat colder before putting it on the grill, or cook it shorter over higher heat.
JUSTWANNARACE
Good idea on checking the grill temp. The things probably close to 10years old
FREE REGOR!!
Looks good what kind of seasoning on the potatoes?
Aren't you supposed to seer it First??
The seer seals the juice in. Letting it rest after it hits Your target temp is key.
I have a Bluetooth ThermoPro. Haven't tried it yet. But I use my instant temp thermometer all the time. 👍🏼
JUSTWANNARACE
I always reverse sear my tri tip. Bring to temp, pull it off wrap in foil, crank the heat to 400, sear for about 4min per side, wrap back in foil and let rest for 10-15 min. Super juicy!!
That's what I bought is the bluetooth ThermoPro!
That seems backwards to me. I want everything sealed inside First!
Yours looks like it has a cable on it? 🤷‍♂️
bonesfab
I have not been able to get the Bluetooth to work on either the built ins or the other kit I bought. The pens work great. They have one that has the pen on one end and an infrared on the other. Good for grill check.
JUSTWANNARACE
The bluetooth on this one seems to work well once I got it paired with my phone
JUSTWANNARACE
I know it sounds backwards but. You dont get it hot enough to bleed out and it allows more of the "smoke" to penetrate the meat.
You should try it sometime it works great!
I've tried it both way and like the reverse sear better on Tri Tip.
dave29
Thermoworks makes killer thermometers. Most of the pros use them. You need a Thermoworks Thermapen. Instant read and allows you to check various parts of the meat in addition to the inserted fixed thermometer.
81Sprint
I’m a big fan of the Meater, never let me down.
I have these as well, never had an issue with meat being over or under cooked. Takes all the guess work out, and it's nice that it gives you an estimated cook time cause that's the first thing the wife always asks lol
Cobalt232
We get the Costco pre seasoned Tri Tips. Put them in the smoker @ 225 until internal temp is 135f. Then into a cast iron with butter to sear. Let it sit for 10 minutes. Easy. I like my Tri Tip more done than most. The leftovers are great for tacos.
TeamGreene
BAM! The best there is.
attitude
Same here, I eat my steaks medium rare but my tri-tip medium, usually 140f ish after the reverse sear.
I would recommend buying the non-seasoned tri tip and getting Kinder’s Santa Maria seasoning from Costco.
PDQH2O
I have one of those as well. My tri-tip yesterday alarmed at least 8 times. Seven of those saying the connection was lost even though I was at most 75 feet away from the smoker. Had to revert to manual smoking techniques. It still turned out pretty well but I’m looking at a different and more reliable thermometer for future cooks.
