IMCO extension boxes
BDMar
B & D Marine
EDIT: LOWERED PRICE
EDIT #2: (1) is sold so I have (1) left.
I have 2 black IMCO extension boxes brand new in the box (pictures below). We bought them for a project that we didn't end up using them on. They are the new style with the bottom corners angled to clear tunnels on cats. Comes with all the hardware.
Edit: Does not include the inner transom plate. Stock Mercruiser transom plates work.
$1500 each.
Boat 405
Neutral boxes or +3 ? Great price btw.
BDMar
B & D Marine
Neutral. I believe IMCO only makes neutral boxes.
AZLineman
Adjusting to retired life
How does the stock Merc plate compare to the Imco?
ONE-A-DAY
What else is needed for an install, longer shaft, steering ram re work?
BDMar
B & D Marine
Longer drive shaft and steering arms that bolt onto the box for the cylinders. (I'll get you those cheap if you buy the box(s) from me)
BDMar
B & D Marine
Bump
boatnam2
So what would we be looking at installed $ with everything needed ?
AZLineman
You beat me to it. Great question because I think I want one.
BDMar
B & D Marine
Do either of you have full hydraulic steering? Need to know before I can give you pricing. Extension box boats require full hyd steering.
boatnam2
B5C7C82F-CD7C-41D4-8A2F-5F22163D3E66.png Current set up
boatnam2
Just to be sure. I'm the cylinders on the outside can be full hydraulic or hydraulic assist which uses a cable inside.
I will check this weekend and get back to you, also sent you a pm.
Boat 405
I did this swap last summer. From a 496 with an xr drive. I bought a box, with arms and a drive shaft and inner plate. Then I had to go full hydraulic steering with the arms, hydraulic lines outside the boat and a bulk head fitting for each side of the box to run the lines into for a clean look to avoid having the lines go through the transom. There was plenty of space in the box to do the necessary plumbing and tees to make it work. The most expensive part will be going full hydraulic. I did a swivel helm, the hydraulic steering box and the custom length lines all from imco and an inline filter. He made the lines to my lengths so everything was fairly simple once I got the lines. This by far has been one of the best upgrades to my 25' daytona. You don't necessarily need the arms on the box, but it's one way to do it. The other way is to change the outside gimbal housing to an imco with the rams built into the side of the gimbal housing, but I think that complete gimbal housing is like $7-8k. It comes with the trim rams and steering rams.
Boat 405
Another great thing about a stand off box is you can get a wrench on the upper swivel shaft nut to change a gimbal ring if necessary. Don’t have to pull the motor or cut up the gimbal housing.
REVENGE 97
I have three of these extra long drive shafts that are in great condition for sale, $200 each plus shipping
Great Price!
She's Mine
Brian, even though they are neutral boxes will the X Dimension be lower on a 27' Daytona because the drive is further back because of the angle of the transom?
BDMar
B & D Marine
It will a little. Even if it didn't drop it would make it act like it's 2" deeper
STV_Keith
Unfortunately Brian passed away earlier this year. His son Dane does have one left though. You can reach him (D1 Performance) at 928-302-3173.
Evo
I know it's been awhile but do you still have one for sale?
I was at the shop yesterday and the extension boxes are not there, so I assume that he sold it before he passed.
STV_Keith
As I posted, Dane told me Wednesday that he still had one.
