H20 Toie
Party on Garth
- Aug 6, 2010
- 6,064
- 23,812
Or i'm really going to make a mess, either way it should be fun to learn,
Hook that thing to the bottles and get after it. Be patient give yourself time to learn.
That’s rad!Go for it,
I bought a Miller 211, not a lesson one, UTube Certified totally built my daily driver/crawler three years ago, I've got 30k on it, and nothing has fallen off or killed anyone.
Welds are ugly, but truck is solid. been to Utah, Parker, Big Bear, JV.
YOU CAN DO EET !!!!
97 4runner, with a mix match of stuff.That’s rad!
Do you have a tig torch for it as well? For the mig side, get yourself a bottle of C25 and get after it. For tig, a bottle of straight argon and lots of tungsten.
Have to disagree with the bed frames. Very high CarbonFlux core wire and discarded bed frames for practice metal.
I'm sure you've already got a grinder and flap discs those are essential for weld prep.
Lots of YouTube videos on MIG welding.
What size tires and what axles, tires look fairly large, but I can’t tell on my phone. Looks good.Go for it,
YOU CAN DO EET !!!!
$50Oh yeah sorry for the thread hack.
What's it worth
It has Tig, Mig and stick, so got all bases covered, its a pretty flexible welder, also will run on 110 or 220 so thats a plus. and if i ever get to that point it will do tig aluminum. you can hook up both tanks and it will auto switch to the one you need,Do you have a tig torch for it as well? For the mig side, get yourself a bottle of C25 and get after it. For tig, a bottle of straight argon and lots of tungsten.
i bought it, didn't come with bottles so need to get them, been reading up on mig welding so will start there, still need to get, helmet, gloves, jacket etc, already i don't like the cart setup so first project will be modifying a tool cart so everything can have its place,Nice machine, regulators and cart.....did you buy or borrow from a friend? Do you have bottles too?
For scrap steel....Just stop by an ornamental iron shop and see if they'll give you some scrap steel tube. They have tons of it. Light & medium gauge under 12" will suffice for starters. Get some plate- 3/16" or 1/8" plate scraps too if possible, small stuff. A 5 gallon bucket full will be plenty to start with. Start w/9 or 12 gauge thick tube so you have a little thickness to work with then move onto 16 GA. That will train you to set your machine and wire size up correctly and move your welding puddle more quickly. Start with .030" or .035 wire and co'2 gas... it's cheapest and most common. Make sure your weld lead liner, contact tips etc. is correctly sized for your wire material. Inside the body where the wile spool goes is a reference guide/chart to help you choose the correct feed and voltage settings for the wire and material your welding. You can adjust from there as you learn and progress.
You pay shipping
I picked one up a while back mainly for the universal 110 got a spool gun for it but mainly using my big 210 , yes the most easily learning tool I have had the kids welding when they were very young
The mp210 is probably my favorite machine in the shop. I like the 215 also but DC only@H20 Toie if the Miller is anything like the multiprocess 210 Lincoln, it should be pretty easy to set up the voltage and wirespeed, it's almost impossible to mess it up on the Lincoln, so I assume the Miller is the same. Your eyes and steady hand are all you really need to worry about. Go get a good auto darkening helmet and a decent set of gloves. If you work in safety sandals be ready for a hot treat between your toes.
I bet half the welders in the US learned to weld on the Lincoln Tombstone. Lincoln still makes it, mostly unchanged.
One last suggestion, when the first spool runs out replace it with quality wire. Don't skimp on the cheap stuff, you'll get frustrating quality out of the cheap stuff, good wire, can make a bad welding machine good and a poor welder better.
Built a lot of stuff with one of those.Is there still any interest in the old coffin box Lincoln 225-s stick arc welder. I've had 1 sitting in the back of my garage for years with about 100#'s of rods. Old roommate left it. View attachment 1422383 View attachment 1422383
This is a badass machine. I have one and it’s awesome. Makes you look like a way better welder than you are honestly.
So…. If a teacher can’t use it what’s it doing at an apprentice training center lol?They have the miller here in San Diego. Boss got mad at me for using it last time I was here so its been untouched in the tool room all year. Some people are strange about using tools View attachment 1422607
Sometimes it’s a dog and pony show around here. Is that the phrase?So…. If a teacher can’t use it what’s it doing at an apprentice training center lol?
Weld. Grind. Weld. Grind. Weld. Grind. Weld.If you can grind... You can weld. lol
Nice. Always wanted to learn!
Where is it located?Is there still any interest in the old coffin box Lincoln 225-s stick arc welder. I've had 1 sitting in the back of my garage for years with about 100#'s of rods. Old roommate left it. View attachment 1422383 View attachment 1422383
If you can gas weld you become a better welder that those that use the auto speed- amp wire dealsSame here. I can gas weld, but that's about it. And I kinna suck at it too!
Fort mohave or HendersonWhere is it located?
