Hellcat-powered Ram TRX is official!
WhatExit?
October 4, 2019 at 9:05 am EDT
Buried in the depths of a large press release on Ram’s history as a standalone brand was a golden nugget: the Hellcat-powered Ram TRX pickup has been approved for production. Details are not yet available, but at the time the TRX was shown, FCA sources told Allpar that the plan was to produce the truck after the next generation went into production.
The concept Ram 1500 Rebel TRX was powered by a 575 horsepower, supercharged 6.2 liter Hemi, with 37 inch Toyo tires and six-piston calipers. It has side-exiting exhausts ahead of the rear tires, built into the rock rails; steel bumpers, skid plates, and “all the cooling you’d want.” It has two spares, and six-point harnesses to hold the driver and passengers in.
Why, people ask, is it “only” 575 hp, when the Challenger does 797 with the same engine? Our guess is two-fold: so you can still control the truck, and because it’s a 4×4, and the transfer case and other powertrain parts can only take so much.
Jim Morrison said it could “handle the harshest terrains at speeds over 100 mph,” aided by a full 13 inches of suspension travel, at all four corners. To support all that suspension movement, they had to make the fenders six inches wider than those of a normal Rebel, resulting in an hourglass shape (as seen from above).
The transmission is the “TorqueFlite Eight,” an eight-speed automatic, with paddle shifters. The 4×4 performance control system works with the BorgWarner 44-45 transfer case, with user-selectable normal, wet/snow, off-road, and Baja modes.
The front and rear axles have severe duty components, and the 13” wheel travel is over 40% more than the normal nine inches front, 9.25 inches rear. Adjustable front and rear bypass shocks are included.
The standard Ram 1500 front axle is used with an open differential and custom constant-velocit half-shafts to handle the wider track; spindles were moved forward to make room for the 37 inch tires. The rear axle is a Dynatrac Pro 60, which uses a selectable electric locker to 35-spline, 1 1/2 inch axle shafts. The locker is available on all modes and “commits both rear wheels to traction at the same speed, spreads the torque load and maximizes the tractive effort (power put to the ground) in full-throttle maneuvers.”
The unique from grille was needed for extra airflow. Inside, it adds not only the six-point harnesses but leather/suede seats, carbon-fiber trim, and new materials and colors.
The frame is “virtually unchanged” from the standard one. The front suspension uses custom-built upper and lower A-arms with special attention to caster and camber angles during suspension cycling. The goal was to have a smooth ride over smaller bumps, and when the bumps become mounds, to have high reaction speed and heat dissipation to avoid shocks while keeping full traction.
The Ram 1500 link coil rear suspension system shares its basic architecture with desert racing trucks; the frame’s hard points for the suspension were unchanged. The 2.5-inch bypass shocks use factory mounts, but performance rear coil springs were put into the factory-spec positions.
The factory hydraulic-boost compensation unit was kept but calipers were swapped out for Baer six-piston monoblock calipers with 15 inch rotors up front, 14 inch rotors in back.
High-speed off-road truck racing teams commonly use a 37-inch tire for its height and durability; hence the Rebel TRX’s 37 inch high tires, 13.5 inches wide, with a 10-ply design and custom Mopar beadlock wheels (which pinch the outside of the tire to the rim). The two complete spare tire and wheel packages, with tools and jack in lockable storage in the bed, reflect the rigors of off-road racing.
Whether the real production Ram Rebel TRX will closely adhere to the concept or not, we don’t know; but we do know Ram intends to dominate all competitors with this one.
See the main Allpar Rebel TRX page for a video and more photos, including under-hood shots.
Black it out, ditch the TJ light bar bed thing, sink the spares lower into wells and ditch the tie-downs on the bed rails...that color scheme makes it look like an early Avalanche with the cladding. Good start, but needs some finishing;)
HCP3
It will look OK without the goofy light bar and cab lights.
Honestly Ford is the only one doing this right. Everyone else is screwing it up big time!
A raptor available with the "base" 5.0 V8 would be my choice....slap that new $7500 Whipple stage 1 725hp blower kit on it and your done
Waterjunky
RDP Inmate #94
So, lets see here. They bought a raptor, stuck their engine in it, and threw the autozone catalog at it.
But at least there is some competition for the Raptor now (Chevy's attempts have been comical sticker packages) and competition improves the breeds.
Riverfamlee
Pic is tagged 2017 wonder how it looks on the new body style. Not a Ram fan but 575 HP out the box is interesting
Yep, this would be a winner. My “regular” TT 3.5 F150 is actually faster than the TT 3.5 Raptor.
Cole Trickle
Cool to have options....
Be interesting to see the price point and I agree foirst thing I would do is ditch all the crap bolted on.
We are considering a used 18-19 Raptor for my wife but the 3.5 ecoboost scares me long term and I would much rather have a 450hp 5.0.
Xtrmwakeboarder
I just wish they would put the GT350 engine in it and be done....
Cole Trickle
Wrong motor low on TQ high on revs..
Honestly the new GT500 6.2 engine detuned would be awesome.
I don't think a truck from the factory needs 600hp but 550 with a ton of TQ would be sweet.
We are considering a used 18-19 Raptor for my wife but the 3.5 ecoboost scares me long term and I would much rather have a whippled 50 state legal CARB certified 725hp 5.0.
Fixed it!
attitude
The new gt500 has the 5.2 block out of the gt350.
The gen 2 3.5 seems generall ok so far, change the oil often though, and get a late 18 and newer with a metal oil pan.
Cole Trickle
They just seems a little hit and miss to me. I can;t justify a 80K truck so I would be shopping used 60K and I don't know the life it has lived with 30K on the clock.
Most seem fine and they run hard I would just prefer a V8 in a truck.
I could never own a ecoboost because of the sound...
The raptors sound like shit. My "standard" truck is silent with the stock exhaust.. You just hear air movement when you get on it.
Agree. You always worry about the moron owner driving part throttle building boost everywhere and dumping heat into it for 30K miles. I don't know if you can deal with the extended cab version, bit they seem to lose value a bit quicker.
As much as I wanted a Raptor, I see even less reason to buy one after driving mine. Without the $6K or $10K options packages that really drive up the cost, the Raptor is a base XLT truck. Mine has all the high end Raptor interior features except the cameras.
They looks bad ass, and ride well, but I'll never use it off road.
Chili Palmer
Master of My Domian
It's like listening to a Kirby Vacuum hooked to a marshal 1/2 stack
It's more like blowing raspberries in a paper towel tube......and every aftermarket exhaust setup still makes it sound like ass.
- Jim Morrison said it could “handle the harshest terrains at speeds over 100 mph,” :D
Make sure you quote that when talking to the service writer
Makes you wonder why trophy trucks need twice the travel to accomplish the same...
pwerwagn
Inmate #4800
Lol...did nobody read the article?
That picture is from 2017 and that press release was from 2016.
Im sure it will be waaaay different than that picture/details.
28Eliminator
What the !!!???? That’s hideous ! Never seen it before. Hope to not see it again.
Lol, yeah... the “Reaper” was a bad miscue in GM’s part.
