Big B Hova
HOSS
- Nov 7, 2014
- 5,745
- 12,522
Is the teak floor glued to a subflooring in a Hallett?
So is the teak the actual floor then? If the teak is soft then the whole floor needs to be replaced?
Really???The teak is a veneer that is attached to wood and that is screwed down to the subfloor.
Really???
Thought it was actual teak planks...
NoSo is the teak the actual floor then? If the teak is soft then the whole floor needs to be replaced?
Really???
You looking at that 97?
Don’t forget motor and possibly the drive.I was but the cost of all new interior and new teak floor would run at least 7 grand. Probably more
I would just throw carpet in that bitch LOLNordic was estimating just the teak replacement around 4000-4500.
So I would increase your 7k.
Whaaaaat? no way, that teak sheeting is about $220 per 4x8 RETAIL.
https://www.marine-plywood.us/teakandholly.htm
Google "Teak and Holly Cabin-Sole"
I'll do my own on my 270. 10, maybe 12 bolts, 20 screws and the interior including the teak comes out. 3-4k, I think someone was hitting the crack pipe a little too hard.I know, looked at doing it myself. Just don’t have the room to do it. Jerry quoted 2500-3000 no sub.
Will someone please help me understand how teak and holly floors shed water? I did a sea trial on a 300 MCOB last weekend and liked the floor, but was curious as to what happens to water in the cockpit. My current Cobalt has a Kevlar hull wrapped in fiberglass with a few SS drains in the floor. It's simple and easy...all the water from wet people and rain simply drains into the transom. In fact, I sometimes drain my huge cooler while it's in the boat. What am I missing with a Hallett floor? The subfloor is just screwed to the stringers? Are the stringers glassed? Does the water shed around the perimeter of the wood subfloor? It's hard to wrap my mind around the 3/4" subfloor being exposed to water, even if it's marine grade. I've searched for pictures and explanations, but haven't found anything definitive. TIA!The teak is laminated paneling it is on 1/4" ply, it's just a floor cover, there is a left piece and a right piece held down with #6 or #8 flat head phillips. Beneath that is two pieces of 3/4" plywood (a front and a back piece), which are held down with 1/4" or #12 flat head wood screws into the stringers), the 3/4" is the structural floor.
Teak floor is screwed to the stringers, everything under the floors is fiberglassed. You need to reseal the floor with teak oil on occasion. The water will drain into the bottom of the boat through the seams on the outside and down the center and into the bilge. You have NOTHING to worry about. Eventually, if you needed to or chose to, you could simply remove the interior, unscrew the teak floor and replace it with new wood...
Thanks for the response. I assumed as much, just trying to wrap my head around the design. For a midwest boater, it's a head scratcher.Teak floor is screwed to the stringers, everything under the floors is fiberglassed. You need to reseal the floor with teak oil on occasion. The water will drain into the bottom of the boat through the seams on the outside and down the center and into the bilge. You have NOTHING to worry about. Eventually, if you needed to or chose to, you could simply remove the interior, unscrew the teak floor and replace it with new wood...
It is hot out there, heck it was 90 last weekend! There is no such thing as dry heat where I live...if it's 85 degrees, it's humid as can be and nothing is evaporating.Also, In the West Coast we get so used to our "local" lakes all being the same that we forget the inherent benefits that come from the environment we're so used to.
For example, IT'S FRACKING HOT HERE!!!! AND DRY! It may be different where you (OP) are, that's why you (OP) would worry about the water or sitting water/moisture. On my 240 the water that would get on the Teak would evaporate in no time. And because the floor is oiled, not lacquered, it absorbs the water and thanks to our DRY HEAT it's evaporated on the ramp in the time it takes you to wipe down the boat.
Am I exaggerating a bit, probably. But still, water on the floor is not a huge concern out here. For any humid or colder climate I would just oil floor more frequently to protect it and use a moisture absorber like DampRid during humid or low temp months.
Did you end up replacing your teak and holly floor? Seems like it would be fun and look great for not much cost.The floor is veneer with a backing and screwed down to a sub floor that is screwed to the stringers. In my 240 water would flow off the wood under the back seat and get stored in the bilge
@BUDMAN - Paul did this to his baby
Paul did the work? lol He might have supervised........
My dad is a TV repairman and has an ultimate set of tools. I can fix it.I didn't, but was ready too and had researched doing it..... Had a quote from Barron boats about 3 yrs ago around $2500. Far better than what others had quoted.
Its not hard if you use your old pieces as a template, I just didn't have the room or time to work on it.
this is good, thanks. I ask that people dry off, but that doesn't always happen. but then again, it doesn't matter in my current boat. I certainly won't be draining coolers in the Hallett.I would avoid heavy water on the Teak floor, it's not a solid product but rather a plywood. Keep it oiled yearly with teak oil, but if you are gonna have people constantly getting in the boat soaking wet no plywood product is going to do great under those conditions.
The teak is 3/8" cabin sole ply screwed to 3/4" resin coated marine ply subfloor.
Having the snap carpet definitely helps to stop water from pooling on the wood.
As far as drainage it will drain to the bilge, but make no mistake, it's not like a liner boat, and shouldn't be treated as one.
