Generator Load Bank questions
SoCalDave
I wish RD would just tell us the size of the generator and the load he's trying to support. That'd be a good starting point.
Taboma
Ahhhh, well, it appears to this reader as though the "Starting point" ship sailed last summer along with the calcs for sizing a proper generator. 🤷‍♂️
I'm going to guess the generator is 10KW and his running load is approx. 2.7KW max.
Seems odd to me that even a diesel generator can't withstand running at almost 30% load, as I'm sure there's job site gens performing duty this daily.
I thought the idea of powering the system off an invertor sourced by either batteries or the gen was a great idea, but is going to require a lot more coin than a load bank. The ROI, depending on actual usage should pencil out over wasting dollars producing heat. 🤦‍♂️
I’m not sure the wattage are pulling right now but I know with everything including to AC units it’s pulling 13 amps. There is a load gauge on the generator and it’s effectively at zero when everything is running.
3120 watts +/-
well then seems like a small genset to support the realistic load of the truck, wired to a x-fer switch, then run the big daddy when needed. very uneconomical the way its setup. like using a jackhammer to crack an egg.
We went with a big water cooled diesel because of the extreme heat we have in the summer. A harbor freight predator isn’t gonna last when it’s 120+ degrees out..
I wanted something that would be bullet proof regardless of weather.. I knew it was going to be overkill but I “assumed” it would be like my motorhome genset where it would be ok if nothing is on or if everything is on. That is not the case.. these big military generators you get a load on them and adjust the generator controls to the load.. (didn’t know that either at the time)
That all said I am perfectly ok with wasting energy. The generator is crazy efficient. At 100% load it burns a half a gallon an hour. We have 85 gallons of fuel on the truck total.
Taboma
Then why is Blackmagic stating the gen needs to run at 7500-8000KW to prevent wet stacking ? He seems to be treating it as a 10KW unit. 🤷‍♂️
2.7KW would be 36% of 7500 and would allow you to offer temp power to others, or your own RV if being used at an event.
This seems as if it should be a reasonable design spec so long as you occasionally run it up with some additional load.
I really think you could pull off the EV charging somehow.
Pad lock with a lock box? QR code you scan to make a payment to get the combo. Apparently everyone says there’s no charging out there.
Great advertising, make a buck or two and lead the generator Rev up a few times a month.
Well I thought it was 7500? It might actually be a 10? I just shot him a text to verify. I honestly did not know that these things had to be loaded down when I bought it. I just figured the more power the better.
The issue with charging batteries is that once the batteries are charged there is no load
Taboma
He responded it’s a 10kw..
Well looking at your problem in a more positive light, with a disconnect switch on the dummy load, when you use this at an event, you'll have power to rent to other venues. 😁
Is an hour or two of “full load” not enough to stop the wet stacking?
I guess I don’t know how much idling is too much?
That was kinda the idea when we were building it. Power the vending trailer etc
Taboma
Pretty much what they desired on the diesel boats I was on that either trolled or worked at reduced load the majority of the time. In other words, kick it in the ass on the way home or go chase a mid-day boil, blow-da-bitch out. 🤪
Bigbore500r
Exactly.
McKay
13A @ 120V is 1560 watts
I'm sure a 10K military generator is single phase at least. The few I have been around even have a 3 phase option. Guessing that's where the the 3120 watts come from.
how's about if it's more in the 220-240v range ?
I know nothing about electricity.. but I believe it’s single phase 220.
You can set it to whatever ya want though.. single phase three phase etc
DaveH
Not exactly.. they won’t survive the summer
dave we ran the piss out of cheap generac generators suppling power to cell towers here in vegas.....24x7 for months on end........it wasnt the heat that did them in here in the summer.
Waterjunky
RDP Inmate #94
Got to say Dave, I know lots of people running the hell out of the predator generators in stupid heat all summer long with less than idea airflow. They have no real issues. I think your overcomplicating this.
What did them in?
To go back to a gas generator would be incredibly difficult at this point so we gotta make what we got work.
McKay
I would still question if you will even have a wet stacking issue but if you believe you will I would look for a 4KW Rack Mounted load bank like used in data centers to test for cooling.
Got a link?
The smaller the size the better
McKay
Here's a 4K.
Here's a 10KW with channels so you could vary the load. Not sure what your sign truck looks like or if you could fit it.
If I could find one a little smaller I could fit it in the cabinet.. that might actually fit as well I need to look up the dimensions
McKay
See the 4K unit I posted next if smaller is needed. These are used to simulate cooling loads of servers before fucking up a spendy server.
Mikemo_SDS
Load banks are essentially just a blow dryer. They use energy by heating an element and blowing air across it to keep from overheating. Make sure it is ventilated wherever you mount it.
Dalton
load bank for 1-2 hours every 1000 hours, it’ll be fine. That’s a 3 phase gen, so you’ll need a 3 phase load bank, ideally.
I have this one-
The load bank mainly enables the gen exhaust to hit target temps, or hot enough to burn off all the crude in there.
When we got that one a year ago small load banks were hard to get your hands on, ended up drawing it out of government stock.
I was just talking with Cummins trying to find out the target exhaust temp for a small diesel gen, they couldn’t tell me, but for their big gens it’s like 900 degrees I believe.
Taboma
That 4KW example is 208V, not 240 and I doubt this generator has the capability to output both 208 and 240 simultaneously as one is Wye and the other single phase, not 3 phase Delta.
Taboma
I have this one-
Can he output both 3ph and single phase 120/240 simultaneously with this mil-spec gennies ?
Why would the electrical side load nature matter, so long as the engine was seeing the proper 75-80% load ?
These can be continuous use right?
Dalton
The main alt/gen is 3 phase, the stuff he’s powering is only single phase I’m sure, he’s probably using L1 and L3, which is fine, but for a full load I think you would want the phases loaded evenly- L1 L2 L3
Bigbore500r
What is running load of the trucks AV setup?
You mentioned the LED panels. Plus the rack of audio gear / amps, plus 2 air conditioners.......I would think you have to be pulling somewhere between 4000-5000 watts when it's all in use? Thats almost 50% load of a 10KW generator. That's not enough to prevent Wet Stack?
