2FORCEFULL
- Jan 26, 2008
- 28,989
- 17,745
here's what ive found,...the 210 is way out of balance, and with the big block weight.. very transom heavy...the next thing is the re entry on the bow... it's just not a wave buster like schiada... so if the boat gets too far off keel.. it'll kite, next thing that happens is when it lands... it's always transom first and it buries deep putting the keel even farther off and with the 21 degree bottom it like to pick a side so it starts the side to side deal..I also found that it's easier to settle down the open bow boats, and it's my belief that they are more balanced...I don't know a lot about the ski race boats, and often wondered if the have ballast weight in the front... I do know this.....70 mph was the scary number for me on multiple halletts ... but tamed way down with a center transom plate....maybe the real fix would be a notched transom.... that's a question for thane....
All the ski race boats I have seen have the drive extension box which helps with the balance issue you are describing, and lots of plate. I have added 12” Dana’s and will probably change the plates to the next size up. The biggest help I have seen is using the 2” shorter drive. Didn’t see a significant speed increase but it did help the handling. Still haven’t found the right prop.[/QUOTE]
are you sure you are not getting too much bow lift?? seems like transom lift you wouldn't be able to put any plate or it would start bow steering,...same with the shorter drive, shorter drive is gonna give less bow lift....right???
