- Apr 4, 2008
- 15,636
- 22,608
Most of my transferring is done either after a semi truck rollover or when one is damaged and needs offloading. I’m not an expert by any means. First time I hunkered down and drilled a 3” hole into the top (which was actually the side) of a rolled 9000 gallon semi tank mostly full of gasoline it brought a new respect for making sure there wasn’t any static buildup.
Uhhh yeah, that would pucker your asshole for sure. Use pneumatic and have somebody hitting you and the bit with a constant spray of water might help. I'll let you know after more testing, if carrying a tile of granite in your pocket renders you static neutral --- portable earth ground, lol
