500bbc
- Oct 16, 2007
- 27,605
- 44,051
Check with steveo143, he's running a TT motor in his 19' Schiada.
Just to see what the setup looks like, what is the shaft angle and how far is the end of the strut barrel from the transom? I have made a lot of changes to my Howard and laying down the strut angle to 7.5 degrees and moving it forward to 23.5" from the transom made the most improvement. That and using smaller dia 2 blades, 11 1/4 works well for me. I agree with Barry, prop size and design will be a big factor in handling.
Your boat should pull 43 gears no problem. That is were I would start, but what do I know... You might even go bigger
I still think it's important to know how much power the engine is making prior to selecting a gear. For example,, Stevo143 runs like 15 lbs of boost or so on E85, so likely his will pull a bigger gear than an engine running pump gas at much lower boost.
WTF, where did the stripper X GF pic go???????????
Word. How much bigger of a gear can a standard casale case hold without modifying the water jackets?
Sorry dude, that was an early Schiada so I pulled it down.
On the subject of prop size and gear selection, I am running what was in the boat when I got it with a slightly snorty NA big block...
Last time this dynoed, on pump gas and on a mild tune we ran 948 hp at 9 pounds of boost at 5800 rpm and an absolutely linear power curve. We had planned on tuning it for a 6500 top RPM yesterday but couldn't get near 5000 without starting to come into boost and getting jiggy.
We made no boost yesterday to speak of (150kp) and it was just unhinged. It has 12% gears (as derived from the 10.2 turns on one side for 10 turns the other or whatever) and I have bought a set of 40% gears from SteveO that I will be putting in this week.
I have a Cary prop that came out of the Cole, but don't know what it's size is... I will check it out today. I also don't know what size the one is on my boat, I just know it is a three blade.
Thanks guys,
Wes
Thanks guys,
Wes
Thanks guys,
Wes
My actual suggestion to Wes via text was "Call prime marine and speak to Mike R. and Mike K." If I had a v-drive cruiser and it had severe handling issues (which it does) that would be call # 1 for me.
I'm not sure why, but I thought this was an early Schiada/Hallet style hull, but no it's a Spectra.
This one did well at one of the Parker Enduro's owned by the Oliver family. They ran a blower motor and I think they GN raced it too. I would get ahold of Joey Cucci at D' Cucci boats in Havasu and ask Joey for Kelly Oliver's phone number. It couldn't hurt to pick his brain and talk some shop. :cool
Twin Turbo v-drives are nice, but how do they do compared to production deckboats tied to the dock at foxes?
The first question every Guy asks when buying a boat is "will this boat get me laid?"
-King Ralph
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Wes, you need 40's or 43 gears, generally as big as you can get into a standard Casale case without machining the water jacket. Castings vary over the years due to casting shift etc. and there is no definite answer to what size gear will fit. Get rid of the 3 blade and use the Cary 2 blade. The Cary's were the best prop going back in the day. The 3 blade will cause excessive torque steer in the smaller and lighter 19' footers. Need to know shaft angle also.
Killer. Gonna go swap them right now. I bought that set of 40's from you and haven't installed them yet. Ironically, I thought the boat would be "milder" for tuning with the smaller gears.
Crossing my fingers that the props are the same shaft size now...
With regard to shaft angle, is this simply a matter of putting an angle finder on the keel and one on the shaft, or is it more exotic than that?
Thanks again Steve.
Wes
Sometimes it's stamped on the whip strutKiller. Gonna go swap them right now. I bought that set of 40's from you and haven't installed them yet. Ironically, I thought the boat would be "milder" for tuning with the smaller gears.
Thanks again Steve.
Wes
OK... now that I'm not working on the V-drive box, I climbed under and checked out the prop. It is a Teague "882" possibly... maybe not There is some corrosion in the middle number. It is an 11 1/2 x 15" three blade.
Propshaft angle is 8 degrees, on the nose.
Driveshaft angle is 8 degrees, on the nose.
Anyone got SteveO's number?
Cool on the prop,, but the next step in your lessons on props is that there are other variables besides the base dimensions that will cause them to make the boat handle differently. I would probably make one change at a time,, so go ahead with the gearbox. Check with Stevo on the spacer, and hopefully he gave you instructions on checking and setting gear lash too (also done with spacers/washers).
You may be able to find someone with a prop you can borrow,, only one I have showed a crack at mag check, so it's a wall decoration now. If you can't find anyone with an appropriate prop to loan,, I think Jim Wilkes has some kind of program, and from what I hear, he makes you try a couple that aren't as good as the "final" one, so that you appreciate "the prop" even more.
You might go to the lake armed with a test prop and prop puller,, test it first with just the gear change and come back to the trailer.
Actually, I don't know if it is a result of cavitation or corrosion, but there are serious pits in the surface of the prop where the ears meet the barrel. The prop will not be making another run in this boat.
And if you hadn't pulled a skier that day... those parts would have lasted forever :thumbsupGood call, I broke a strut once pulling a skier for magazine photos,, was a pretty expensive day for me being a nice guy by the time I replaced strut, propshaft, prop, blast plate,, and had the fiberglass repaired.
Just being the smartass I amNah,, just saying it was pretty expensive for me to help a friend get his photos in a magazine.
Boat didn't do anything funny, or take on enough water to sink, but was running about 90 mph on the straights with him, could have been quite a bit worse.
We were required to mag rudders each year to race, and I got my prop done at the same time, but nothing more than visual inspection on the strut.
That could have been UGLY! I'm glad you're still here to tell the story! :thumbup:
One would think the intercooler would make a good hand rest.
Thanks again Steve.
Wes
Wes, I will call you in the morning after an 8:30 am Dr. appointment to get stitches removed from some skin cancer surgery. The gears that were in it are not 12% over, they are at least 40's. What size is your prop shaft, 1" or 11/8"? I have several diff. props. My number is 714 579-7857
While it was apart, did all of the underwater gear get checked? Now that you've put some serious ponies in it, you'll want to be sure that this doesn't happen.........
No... it didn't. All of the underwater hardware is flush mounted and bedded with what looks to be Sea Goin' putty. I didn't want to dick around with pulling it out, as it was all really clean and nice looking, except for the prop.
Additionally, the hardware was all chromed, so I am not sure you can inspect it properly with a mag.
In any case, I will likely have to pull the rudder and prop and check them out at least, but the strut may have to wait until after the season.
