JLG614
Signature Garage Design / Epoxy Flooring
- Apr 17, 2017
- 542
- 1,995
Unfortunately not at this timeDo you do work out here in Mohave Valley? Posted before reading above post lol.
That would be my brother Don of Fantasy Rigging, and yes his work is a definitely amazing.is this the same Mumma that rigs badass flatties?
Hell ya it is.......will he be working out of that space too?That would be my brother Don of Fantasy Rigging, and yes his work is a definitely amazing.
That looks amazing...
They use a stencil and a concrete stain, they can do multiple colored layers if the logo requires it. and the nice thing the floor is super durable and no maintenance.What's the logo material? How is it applied?
Does the stencil adhere to the floor to keep the stain from bleeding beyond the edge? The lines apear so crisp and straight.They use a stencil and a concrete stain, they can do multiple colored layers if the logo requires it. and the nice thing the floor is super durable and no maintenance.
The stencil sticks to the concrete. But the way it adheres and the stain applied without bleeding is a trick they keep to themselves. I asked the same question.Does the stencil adhere to the floor to keep the stain from bleeding beyond the edge? The lines apear so crisp and straight.
No dust, it is all captured with equipment, one of the passes required a small amount of water but it all depends on your concrete and what each layer reveals. There is no top coat per say , they do use a certain type of spray that hardens the concrete between grinds. so there is nothing to peel up or refinish in the future as soon as they leave the building you can move equipment in.Is the grinding process dusty or do they capture all the dust as they grind w/ a vacuum system? Do they use water while grinding too or is it a dry process? Will you have a sealer/top coat for the final finish?
Your project came out looking amazing congrats. What is the name of the company that did it in Havi? Thanks G.No dust, it is all captured with equipment, one of the passes required a small amount of water but it all depends on your concrete and what each layer reveals. There is no top coat per say , they do use a certain type of spray that hardens the concrete between grinds. so there is nothing to peel up or refinish in the future as soon as they leave the building you can move equipment in.
OC Concrete, They are located out of Orange County, but they have a small division here in the Mojave area.Your project came out looking amazing congrats. What is the name of the company that did it in Havi? Thanks G.
Thanks for the info.OC Concrete, They are located out of Orange County, but they have a small division here in the Mojave area.
