whiteworks
Custom Shutters by WhiteWorks
- Sep 25, 2007
- 15,933
- 11,347
I’d like to get my car dyno tuned, who’s the eco tec guru?
Upland, no clue I just bought it, I’m just a dumb carpenter LOLwhere you located? what engine manegment system?
assuming it has a GM ECU and ran good before......why would it need a "tune"? i ask because i own a dyno and see this all the time........where there is a mechanical or wiring issue but nobody can work on anything any more and therefor assume it a tune problem.I’d like to get my car dyno tuned, who’s the eco tec guru?
Runs good at while cruising it, stomp on it and it falls on its face, let off and it goes. Bought it about 6 months ago, took it out for a test day and it was good, but I had the wife and kid in it so we just putted around. Then I had it out at KOH for a week and it was good, ran it around mostly cruising and getting used to the handling of the car. I noticed that it would cut out a bit that week and just drove within the limits it worked well.assuming it has a GM ECU and ran good before......why would it need a "tune"? i ask because i own a dyno and see this all the time........where there is a mechanical or wiring issue but nobody can work on anything any more and therefor assume it a tune problem.
the MOST common problems develop in the fuel system. these cars sit with pump gas in them and foul up the fuel system and injectors.......throw into the mix all the dirt from offroading and fuel cell foam breaking down...........
DI or port injected?Runs good at while cruising it, stomp on it and it falls on its face, let off and it goes. Bought it about 6 months ago, took it out for a test day and it was good, but I had the wife and kid in it so we just putted around. Then I had it out at KOH for a week and it was good, ran it around mostly cruising and getting used to the handling of the car. I noticed that it would cut out a bit that week and just drove within the limits it worked well.
After KOH I took it into a shop and had them replace some seals on trans, plugs, wires, oil change, air filter and go over everything a bit. It feels like a fuel mapping issue to me, but that’s just a guess, I can’t say that it wasn’t like this before as it’s new to me. Fires up and purrs like a cat, all good until you romp on it.
thoughts?
Thank you for the insight, having a 20,000 foot optic of the situation is all I need. it’s getting dropped off with Bruce at CBM next week and sorted by someone who knows some shit I don’t know and messes with this stuff every day.DI or port injected?
definitely get into the fuel system. proper filtration is a must, need a 100micon (stainless screen) filter before the pump and 10 micron (paper element) before the injectors. flow or replace the injectors.
could be a bad MAP sensor (had that one other day) or bad throttle position sensor. can also be wiring. many of these cars have a small 4 position fuse block for the engine harness with blade style fuses. sand and grit works its way in and causes an erratic connection.
Danzio or Redline
We have used turn key in the ultra4 cars for the last decade, flawless the entire time. I’ve had multiple people point me to CBM that run some pretty serious buggies and also a friend called the owner today and let him know I’m coming out. My car is just old school stock stuff, nothing special and for anyone who has a clue, Id imagine it’s a walk in the park. My expectations are very simple, just needs to do whatever it’s supposed to do, nothing more, nothing less. Like I said, it causes me any grievances and down the road it goes LOL.@whiteworks i will say though if its a factory gm computer turnkey has those figured out. When i used to race a 10 car we had a factory computer from turnkey. The 10 car team i help out now runs a motec with a danzio tune. My personal car is a ls2 with a redline tune.
I dont want to stir the pot with CBM as i have never dealt with them directly but have had mutliple buddies have terrible experiences with them.
Ass, gas, or grass, no free rides on that programNo RDP SUX sticker??
I’m guessing your on the right track with that thought. I think it will be short work with for an experienced shop to diagnose and resolve. I’d put our team on it, but everyone’s running businesses and will bust my balls for getting $5000.00 an hour in manpower on my stupid little buggy issueSounds like a fuel delivery issue to me, I would start with a new fuel filter, check fuel line pressure, throttle position sensor.
Also there are a couple of sensors that can be swapped pretty easily, it will run but then fall on its face. We scratched our heads for a month trying to figure out why the engine, harness, and computer that we just installed from TurnKey wouldn't run right. A quick email to them sorted it out, I swapped the sensors and now it runs like a raped ape.
Sent from my SM-G988U using Tapatalk
I just looked at the email, it was the cam sensor plugs that were reversed. You might try that before you take it in for service.I’m guessing your on the right track with that thought. I think it will be short work with for an experienced shop to diagnose and resolve. I’d put our team on it, but everyone’s running businesses and will bust my balls for getting $5000.00 an hour in manpower on my stupid little buggy issue[emoji23]
Some of you guys don't seem know much about CBM.
He will definitely not need to go anywhere else ...
Login • Instagram
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.instagram.com
Like i said above i havent dealt with them directly but know multiple friends with terrible experiences. Have a good buddy that was royaly bent over from them with no lube a couple years ago and after spending the majority of the first trip in the middle of the desert fixing there shotty work i lost any confidence i had in using them in the future. Was also in barstow 2 weeks ago with some buddies testing a class 1 car that had finally ditched the cbm motor that has been nothing but trouble and had a new motor built from a different builder, I can go on with more Stories but they are all not my personal experience. I know there are plenty of happy cbm customers but i have met quite a few unhappy ones.
I guess I should have come by the hangar!!!!! lol
Problem solved.
