In easy terms, its a flat triangular spot on the back of the hull in the center that the boat rides on at fast speeds. It's very efficient. Boat brands that use pad bottoms to great success are Allison and Velocity.
...as far as Jet Boats go, the bottom doesn't really matter..The intake is basically a 16"x30" pad with a hole in it to suck/pump water..you are never really riding an the "pad"..The ass of the jet boat is "stuck" to the water..the "set" would be controlled by ride plates & jet-o-vator/trim angles..
I'll have to get a picture of mine this weekend. That one on the 27 looks way smaller than the one on my 24.
I remember when the delta pad was "the" tech upgrade..........everyone started............and fountain did the variable delta...........their pad was not a true delta......four sided as the 2 sides didn't meet and was square at the front and had a variable deadrise(got flatter towards the back).............delta is a good design unless taken too far.................brother had a cole skier and the pad was sooo large, the rocker of it affected the ride(lack of power porpous) and when turning hard, you could feel a dramatic shift to the running surface............like you could feel the bottom slam from one surface to the next...................from straight, to 20 degree bank, without anything in between..........the delta was like 18 inches and went about 8-10 feet forward on a 21 foot boat..............
It'll be interesting to see how wide the pad on your 24 is. What boat is it?
The small notch on the Tuff 21 does the same thing, allows the 300 to run higher by getting clean water earlier. Most pads will have a small amount of deadrise to soften the landing, but if you want those last few mph's flat is where it's at.
Yep you are spot on, they came in all shapes and sizes. 18" wide on a 21 foot boat? Holy Moly that is crazy!
Here is a picture of the delta pad on a 2013 Tuff 21 which is evidently the worlds fastest single outboard "V" hull. It does 102 GPS with a stock 300XS. Pad's have there place for sure.:thumbup:
Worlds fastest outboard V hull??....cough cough!! I think Allison owned the record for a while at 128mph!
The second photo looks like the 'pad' has sides on it that are not even with the V-section. It also looks like the 'pad' is parallel to the forward keel line. (at a different level/height) It may be a 'pad' bottom, but it does not look like the traditional 'delta pad bottom' as they have been done in the past. A 'delta pad' is actually just an 'angled slice' off the keel line, rising to the transom. (no vertical sides, infact it is blended into the original V-section for control at speed) Many hull bottom designs (big and small) use a narrow center section, that usually has 'very little V or a flat area in it'. This narrow center 'riding surface' may be the most deep part of a hull even with a 24 degree deadrise out to the chines. The word 'delta' in the term delta pad refers to the fact that the 'side angles are straight lines and they intersect (in a point) somewhere forward of the transom. I don't see a 'traditional delta pad' in your photos. I do feel that the 'top photo' does show a 'delta shaped pad', but it also looks like it too has 'vertical sides' on the pad section. If it does actually 'blend into the V-section' on the sides, and create 'false rocker', then it would be a 'delta pad' bottom.
How about this bottom...........?
No that is not a 'delta pad', because I see "sides" on that pad and it does not intersect the hull at the keel or the v-section. It looks like a 'pad' that is deeper in the water than any other part of the hull. It looks like you must 'drive the boat UP onto that pad' and it's curved (sharpe sided) leading edges, would make it 'unstable' (pushing water) if the boat was unable to ride all the way back on the flat area. It also looks like the 'pad' is on the same plane as the keel, which means it offers no 'false rocker' that a delta pad is known for. The bottom in this last photo would have much less drag and much better control if you made some major changes to it. We can stay here to discuss or move to PM to clear out the traffic here. I mean no disrespect, but you can reduce a lot of drag with a different design.
Funny, I was thinking the same thing...in that I dont recall ever seeing a delta pad that extended lower than the hull as this one does. And by at least a half inch to an inch from the pic. Even up on plane it strikes me that it would be a heck of a drag on the hull...most pads that I have seen are flush with the running surfaces of the hull....not extended down below them... am I wrong?
That baby has had a ton of bottom work done to it, and it looks like all the work was in the correct direction. Just enough 'delta pad' to give a little false rocker and just enough 'flat surface' at the transom, to counteract the prop torque. Thanks for the pix, you have a "one of a kind" boat there.
That's a cool pic! Wondered where you were hiding lol!
Can someone please define the word "rocker" for me...and then explain what a "false rocker" is?? Thanks....
A 'rocker' is just like the rocker of a rocking chair, a curved area of the hull that will allow the boat to 'sit-back' onto the (hopeful) 'sweet-spot' to carry the nose. Less wetted surface = faster boat.
'False-rocker' I have no idea. Maybe like false labor pains? I dunno, George should be along soon to correct my description.......
