530RL
- Sep 18, 2012
- 23,133
- 22,576
When you need to go snowmobiling in a hurry.
Looking much better Ziggy. The first one was5 weeks post surgery, non-zipper scar.
Since it was glued together vs stitches I call it my ziplock scar.
Hell Yeah
Good God that is legit.
French engine, no idea on the rotor system yet.Good God that is legit.
NopeJust hop in and it takes you where you want to go like a Waymo.
No pilot, no nothing.
View attachment 1486576 View attachment 1486577 View attachment 1486578
That’s exactly what every pilot at the show said.Nope![]()
Love the filter on the picture and the canoe!!
Progress but it looks Like a big PITA. I hate roots in the yard. Did you HOA cite you for the dumpster and parking on the street?Took the damaged panels out with a bobcat and removed most of the roots using a sawzall, cable and the bobcat. There's a big root running along the left side that is about a inch below top of concrete so it has to come out but it won't move. I have a plan for the morning, need to get a couple chainsaw chains, I will win.
View attachment 1487419 View attachment 1487420 View attachment 1487421 View attachment 1487422
No HOA hereLooks Like a big PITA. Did you HOA cite you for the dumpster and parking on the street?![]()
Never, ever fun when those are spinning.
Someone having a rough day at Glamis
View attachment 1487671 View attachment 1487672 View attachment 1487673 View attachment 1487674
Any details? Big block, small block?Met a cool neighbor at the gas station View attachment 1487710
I'll ask next time I'm up. Didn't want to bug him too much. Sounded bitchen though!!Any details? Big block, small block?
Where is this?
Lake nacimiento. Heritage rampWhere is this?
Hey! You never answered my question - Do you have to be a math wizzard to haul this large stuff and figure out weights and what your trailer will carry and where the load should be placed and where and how many tie downs and what they will hold, etc etc. Then the whole fuel burn and how heavy a load is etc vs. what they're paying you to haul it...Seems like it'd be a lot of figuring shit out. Do those having you haul stuff certify the cargo's weight? Do you use that freight website to just pick your loads?A cool 2700 miles last week. And by cool I mean rained the whole damn time up and back. The wing segment came from Santa Ana and delivered to Boeing in Everett Wa. Then I picked up a reload in Everett back to Pomona. View attachment 1487863 View attachment 1487864 View attachment 1487865 View attachment 1487866
Ok I’ll try and answer your questions to the best of my abilities:
I’m no math wizard for sure. When I book a load, the shipper has provided the DIMS to the broker, so I know what to permit for. Weights, length, height, width, etc. My truck has scales on the bags so I know what kind of weight I’m running on the drives and trailer. Often times the load will be different than advertised and I’ll have to get new permits. This load was 16’ wide, so it took two pilots to get it moved. The routing will change based on the DIMS, so I’ll try to get more money based on increased milage. The loads usually are a rate per mile deal, and just like anything else, that can be a tricky number to nail down. After enough time you know what it’s gonna take to run. As far as axles go, I take a peak every morning on pre trip, and in the evening in post trip, for a wet tire. Once a week I’ll get underneath and look close at the seals to see if they’re weeping. I don’t cook the brakes because I know how to drive, that usually is why the seals fail prematurely from the heat.
Load securement is another subject. When in doubt, I give it a goooog to determine the G load, and appropriate chain size, and rigging. Im never running very heavy, so 1/2 grade 70/100 indirect usually nails the number for load securement. I started this company with zero experience, or training. I learned everything from YouTube, and by asking questions, and observing other people’s setups. It’s not rocket science, but there is a standard that needs to be followed, and that data is available if looked for online.
what happened there? Looks like the hub on the drive axle blew out?? never seen anything like that.Someone having a rough day at Glamis
I have no idea, the way the cap is mushroomed looks like it was fluid that blew it out. The pumpkin on the axle was leaking bad too.what happened there? Looks like the hub on the drive axle blew out?? never seen anything like that.
