- Sep 18, 2007
- 22,350
- 50,811
Len that is a major bummer, i know you have put a lot of time into finally getting this boat running, everything turned out so beautiful too
I realize that, but why? I was more so wondering if something was overlooked during dyno tune or if something went wrong with installits very simple actually.
not enough fuel
too much timing
poor quality fuel
or any combination of the three items listed above.
i can think of a lot of reasons.I realize that, but why? I was more so wondering if something was overlooked during dyno tune or if something went wrong with install
agree 200%.The dyno has a dedicated fuel pump and regulator. This customer owned fuel pump and regulator could be the factor that created the lean condition. A test on the fuel system may be in order along with the rebuild.
@Bajastu what would such a fuel system test look like?The dyno has a dedicated fuel pump and regulator. This customer owned fuel pump and regulator could be the factor that created the lean condition. A test on the fuel system may be in order along with the rebuild.
30 degrees total, locked out.What a bummer. Hopefully the rest of the parts are fine and you can get away with a set of pistons. Do you know what the timing was set at? Is it locked out, or do you pull timing with boost?
The line from the Outlaw Josie Wales film keeps popping into my head: โEndeavor to persevereโLen that is a major bummer, i know you have put a lot of time into finally getting this boat running, everything turned out so beautiful too
Crank trigger or internal distributor pickup for timing?30 degrees total, locked out.
Just like what Racey said, ask your builder to use your pump and regulator on the dyno. They can measure fuel PSI, GPH, and make sure that it is keeping up with the boost pressure regulator vacuum reference port.@Bajastu what would such a fuel system test look like?
Where are you taking your fuel pressure reading from? Mechanical gauge?Wooo, lots of questions.
Crank trigger or internal distributor pickup for timing? No crank trigger, MSD billet distributor with internal pickup.
Data logging would be nice, especially right about now. Iโll ask the builder about possibly switching to a crank triggered set up to gain some of the benefits mentioned.
Definitely will dyno this time with the currently rigged fuel distribution set-up. I do have a fuel pressure gage on the dash, I did not see it deviate from the 7-8 lbs the regulator is set at. That said I was watching for a lot of stuff on the shakedown runs.
Current fuel distribution system: two new IMCO 35 gallon saddle tanks, 1/2 inch npt bungs, #8 lines from each tank that tee into a #8 line that feeds a Baker Engineering mechanical pump and a parallel Aeromotive electric pump that is used principally to fill the carburetor bowls at start up and then shut off. The Pumps feed a Teague fuel log and are check valved to prevent back/cross flow. #8 line up to Aeromotive four port fuel pressure regulator. #6 lines feed each bowl on two billet 1050 Dominators.
First run last fall the tanks were 1/2 full of fresh Shell 91 octane. Second run last Thursday the old fuel was drained and fresh Shell 91 octane was filled to 1/2 full.
Spark plugs: donโt know the heat range and I am out of town through Sunday. Iโll update when I get back. The plugs have the dyno runs and two hours of shake down time on them.
Boost gage showed 5-6 lbs the one and only time I got into the secondaries before I noticed the smoke pouring from the breathers.
I spoke to Len on the phone this morning. Let me assure all of you that he is dealing with a top notch engine builder and dyno. Len reminded me that we spoke years ago when he was getting started on this. I am sure it will get sorted out.
here is your data logging setupWooo, lots of questions.
Can you walk me through your thinking here? In other words whatโs wrong with it and how should it be set up? Really just trying to learn.from the pics, those plugs are not too hot. when the plug is too hot, the strap will glow red hot burning any carbon off it.
i would bet this was caused by poor fuel delivery. there is no way you will have steady unaerated fuel delivery with the setup you described.
the problem is the fuel tank.Can you walk me through your thinking here? In other words whatโs wrong with it and how should it be set up? Really just trying to learn.
I completely understand this concept in an EFI set-up. I have run a pressurized secondary tank on my EFI set-up from day one. I pump to it from the saddle tanks with low pressure pumps and feed the high pressure fuel pump from the secondary tank. However, I don't understand how this is that critical on a dual carb setup. Obviously air is bad but there is: 1) a reserve of fuel in the float bowls and 2) an escape for the air in the float bowls before the fuel enters the engine. Neither of those are present on a EFI.the problem is the fuel tank.
ive yet to ever see a marine tank that has proper baffling in it. the more you accelerate, decelerate, turn, the G forces.....the fuel becomes violently "washing machined" and completely aeriated. this wont be visible to a pressure gauge as air is compressible and dumb gauges cant tell the difference between air and fuel or a mix of the two. keeping the tanks FULL lessens the issue but it is there nonetheless.
you need a vapor separator tank with feeder pumps to fix this. Kinsler EFI makes them and the associated components to go with it, or they can be custom made your specific application. seen many turbo motors melt down over this very issue.
Vapor Separator Tank: 4" diameter x 12" tall, blue anodized aluminum - Kinsler Fuel Injection
Note : Image Shown is of 3" Diameter Tankkinsler.com
you are correct the need for stable fuel delivery is even more import with EFI then compared to a carb.I completely understand this concept in an EFI set-up. I have run a pressurized secondary tank on my EFI set-up from day one. I pump to it from the saddle tanks with low pressure pumps and feed the high pressure fuel pump from the secondary tank. However, I don't understand how this is that critical on a dual carb setup. Obviously air is bad but there is: 1) a reserve of fuel in the float bowls and 2) an escape for the air in the float bowls before the fuel enters the engine. Neither of those are present on a EFI.
I am not challenging your theory, I'm trying to wrap my head around it.
This sounds very familiar hahathe problem is the fuel tank.
I spoke to him on the phone the other day and mentioned that only a couple of guys tried Dominators on ski race boats and didn't get good results, that the 830 was the carb of choice for that type system.1050 dominators are a lot of carburetor for a 975 hp turbo motor. We did a 1300 hp gentry/turbonetics motor with 830 annular no problem. Whatโs your compression to make 975 at only 6-7 psi boost?
I think you are critically lean somewhere with your carb setup. Perhaps the top of the primaries. Perhaps everywhere. Itโs hard to believe a short burst at 5000 rpm would cause that kind of piston damage. If you arenโt replicating a proven carburetor setup, you NEED to run the engine in the boat at all throttle application levels with a wide band air fuel meter. WOT dyno pulls are useful for getting in the ballpark but are not representative of having the motor dialed in running in the boat. It needs to be richer than a lot of drag race tooners thinkโฆ
Good luck JT
Hope it gets fixed and back in the boat quickly. Sorry you had to do all this work. You are a true craftsman who built an incredibly nice boat. The next chapter will end better.Not how I wanted to spend the Monday before the 4th.
A couple of take aways from the owner of the shop that built the motor:
A/F ratio, exhaust temp, and boost were monitored independently back when the engine was built (2017) and would have been a part of any dyno run they performed.
He said standard protocol would have been to run the engine at all RPM ranges to assure jetting was correct through out the intended operating range of the motor.
The tech that assembled and dyno tested the motor isn't with the company any longer but they will search back through their paper and digital records to learn anything they can. They have since installed a new dyno so the original dyno runs are on an old hard drive that may or may not yield results.
They will tear it down this week and report back.
He recommended that the turbos go to Carson for evaluation and/or rebuild.
Current lead time for new pistons is 4-6 weeks.
He is committed to turning it as fast as he can, this was not the way he wanted to see me again. Overall very happy with his approach so far.
Glad you're moving forward on it quickly. Very interested in finding out what you learn.Not how I wanted to spend the Monday before the 4th.
Hoping the summer is a long one this year, might still get some time in the boat if the stars all align. My plan is to share what we find, maybe it will help some other lunk like me someday.Glad you're moving forward on it quickly. Very interested in finding out what you learn.
Is that your place in the picture?
Your gantry is bitchen! the rest of the shop is ok too.Hoping the summer is a long one this year, might still get some time in the boat if the stars all align. My plan is to share what we find, maybe it will help some other lunk like me someday.
The shop in the pics is mine. When I retired we built a home in Shasta County, CA. Well more accurately my wife got her dream home and I got my dream shop. I have built and repaired plenty of cars and boats in driveways and side yards, the shop is a lot better.
I think it's a challenge with wet exhaust and/or short tailpipes where the o2 sensor is too close to fresh air.Does any boat people put air fuel gauge on? One of the most important gauge imo.
He had Imco place bungs into the exhaust near the turbo. they go through the water jacket.I think it's a challenge with wet exhaust and/or short tailpipes where the o2 sensor is too close to fresh air.
