Done-it-again
- Apr 3, 2016
- 9,482
- 11,955
Unfortunately I did. I did get 10yrs of tank flush cleanings. Lol.You actually paid that?
Aka drip tee...Need a water bond , some cities gas line bonded also.
Also your specialty gas line needs a dirty leg - sediment trap.
Backflow valves are installed after the meter. All appurtenances installed after the meter are the responsibility of the homeowner. Most rural houses have them and in CA they must be inspected each year by a certified company to be compliant with the water agency. I've owned two houses with them, and I was very familiar with the process. It’s just a cross contamination prevention system especially if you have a house on elevation which will increate the PSI and can back feed the system.Are the backflow devices being installed on the line to your house ? If that's the case, then hopefully it's not your responsibility for testing.
Damn, around my hood we'd kill for that high of water pressure, sure make landscape watering easier. If they install individual backflow preventors, you're going to lose a couple of PSI, but you probably won't notice a difference. But when you've only got 35-40 like some of my neighbors, dropping another 4-5 psi sucks.
I've read that folks install expansion tanks to mitigate water hammer, especially on a closed system. I'd always assumed they'd both be tapped from the cold water side prior to any check valves or other restriction devices and would serve dual purpose.
Our district only requires them on homes with interior fire sprinklers, which were required by the new code. The older homes around me do not have BF preventers.Backflow valves are installed after the meter. All appurtenances installed after the meter are the responsibility of the homeowner. Most rural houses have them and in CA they must be inspected each year by a certified company to be compliant with the water agency. I've owned two houses with them, and I was very familiar with the process. It’s just a cross contamination prevention system especially if you have a house on elevation which will create more PSI and can back feed the system.
75 Gallon It’s a very easy swap. I would have told the first and second to go pound sand! Super easy.Just got 2 quotes to replace a water heater in Eastvale. 75 gallon Bradford White (gas) with VERY easy access. First quote $4900+ Second quote.........almost $10,000 WTF!!!!!!!!!!
